I'm having new drapes made and found a local lady to do them. Agreed to attach the plastic carriers ourselves to lighten her job up a little (she's 83).
Anyway, I don't know sewing. If you've done this before how did you attach the plastic carries in the photo. Did you do them by hand or with a machine? If with the machine - are there any special tricks to the trade?
If you have the drapes done by James P. Ambruso, he doesn't use those carriers...his have rings at the ends, and he loops elastic material around and sews the elastic to the drape.
James has been doing Airstream and Argosy drapes for quite some time now. He's expensive, but the drapes are an exact match to the trailer. Just tell him what year and model you have and you get what you pay for.
Note: There are at least 3 or 4 different types of hangers and tracks out there. But they won't all fit all coaches. The sew on ones are the only ones that will work on my tracks in my 71 (I think!)
Thanks for the tip. I want these to have the same vintage carriers and rail usage as the ones in it now. The current drapes were done by Airstream in 1988 and are the pattern for the new ones. So they will be an exact match - except better material and a better liner and double seamed pleats instead of the Airstream single seaming.
I'm a firm believer in you get what you pay for - you just have to be careful in who your gettin it from or you'll over pay.
Thanks......
Airstream sewed those drape tabs on for several years.
They are called "kirsch drape tabs."
Airstream used them in 1968, 1970, 1971, and 1972.
They did not use them in 1969.
1973 and up use "G" and "T" tabs.
We have them as well as a few other dealers.
My 1969 use the exact ones shown in the photo above on the side windows. the front window because of the curve uses the one with rollers. I just made curtains for my A/S and I hand sewed all tabs and slides. Note I put those type in the photo above into the pleat as it gave you the space you need to keep the pleat from dragging in the upper track (Side windows only).
Hi Gary. You have the same type that I have in mine, the ones with the screen. I sew them in with a machine. Once they have been sewn through a couple times, they become weak. The good news is you can also use the type that is in the attached picture. They work in the same track and use elastic. They work much better and will last longer. You can get them at Vintage Trailer Supply - Vintage travel trailer parts and supplies! . They are called Large curtain carriers. Good Luck. You can email me if you need any help.
Tammy
Hi Tammy - boy I was hoping you'd show up. So your using like a 3/8th wide strip of elastic and the tabs in the photo instead. Do you sew down close on the elastic to the tab so the drape doesn't sag at the top? (keep in mind I know nothing about sewing). Thanks much for chiming in - I'll post a photo of these when done - the lady really did a great job.
Tammy
That's exactly what I have in mine. The elastic is threaded through the ring and then sewn to the drape. I think it's a better design than that mesh plastic.
