Old 01-20-2009, 06:33 AM   #1
Phantom's Avatar
2007 19' Bambi
Delton , Michigan
Question Door curtain for 2007 Bambi
Hi Everyone...
We had a rather new 2007 Bambi Safari. I had the frosted door glass replaced with very dark plexiglas so I could see people at the door. Now we need a curtain for the evening!. I want to mount some type of curtain rod on the rounded, curved, padded header over the door. My thought is for a simple, thin rod of some sort... a two-part curtain with perhaps small squares of velcro at the sides and bottom to 'stick' the bottom edges to the aluminum screen door when closed. Has anyone mounted a rod to this padded header? Any opinions on curtain types or material?... or if I can 'match' the other white curtains? All opinions welcome.
Phantom
Phantom is offline   Reply With Quote
Old 01-20-2009, 10:53 AM   #2
1998 28' Excella
Dolores , Colorado
I would suggest getting some solar screen that allows you to see out but nobody can see in. We have used it in our home before especially in the winter when the sun is in the southern most hemisphere and we won't roast in our family room which has a southerly exposure.
Member 4CU/CAC
dogpound is offline   Reply With Quote
Closet in '62 Bambi - Door? Curtain? Open? dudebb 1961 - 1963 Bambi 2 06-04-2007 07:59 PM
2007 - Dave Winick 75th Bambi 19ft or... campadk 2005 and newer - Bambi all models 29 11-08-2006 02:58 PM
2007 19' Safari Bambi w/ new wd hitch 64Vette Hitches, Couplers & Balls 37 09-05-2006 11:23 AM
Curtain Pattern for '62 Bambi Marshall44 Upholstery, Blinds, Walls & Interior Finishes 15 03-17-2003 07:03 PM
door hinges wb13798 Mechanics Corner - Engines, Transmission & More... 13 02-05-2003 06:36 PM
