Old 12-27-2008, 04:24 PM   #1
flashgrbiv's Avatar
1965 17' Caravel
Hood River , Oregon
Delamination repair
Thought I'd share my experience fixing some delamination in my 65' caravel. Age or humidity had caused the top layer of wood to delaminate near the stove and in several other places. I came up with a method of repair that seems to have worked.
Supplies
Several large bore syringes (larger bore is for strength not fluid flow)
Clamps
Superglue
To prepare I set up for clamping the area somehow. For example, to clamp the panel next to the stove. I used a large flat peice of solid hardwood and wedged it against the panel using a long peice of wood going from the sink to the wall. Any method of clamping will do.
Once I knew how I would clamp. I removed the clamp trial, and sucked up Superglue into the syringe. Then I would use the syringe to penetrate the upper delaminated layer of wood and dump the superglue behind the delaminated layer. I did this in multiple locations gradually moving around the delaminated area making sure to get glue in all locations. I then clamped it up for a few hours and was done.
The nice thing about this is it did not damage the upper layer's finish and allowed me to keep my trailer as orignal as possible.
Good luck.
George
flashgrbiv is offline   Reply With Quote
Old 12-27-2008, 05:46 PM   #2
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
Do you have any pictures?
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
LY fiberglass side delamination Santart Land Yacht/Legacy Motorhomes 27 11-26-2012 04:15 PM
shop repair of 1970s rear frame separation (non elephant ears repair) RV shop review simonhanbury Repairing/Replacing Floor &/or Frame 49 06-24-2008 09:16 AM
Need someone to repair my AS Folkie53 General Repair Forum 3 01-25-2008 06:48 AM
delamination fixes ? myfirstrv General Motorhome Topics 6 12-22-2006 07:53 PM
Ceiling Delamination gunworks Land Yacht/Legacy Motorhomes 4 10-19-2006 11:55 PM
