Old 02-23-2011, 09:21 AM   #1
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Cushion clips for '64 overlander goucho???
The PO started taking the fabric off of the original goucho, with the 2 side wedge shaped arm rests. The problem is, she took the clips with her. I don't know what they looked like. There are 2 metal brackets on the walls that I assume were for the arm rests, and there are 2 clips on the wall to hold what I believe was the goucho back rest from flipping forward. Does anyone have a picture of what these looked like?
thanks!
robwok is offline   Reply With Quote
Old 02-23-2011, 01:45 PM   #2
VIKING's Avatar
Boulder Creek , California
I didn't have clips on the arm rests, just on the back cushion. I can't seem to find a picture of them now. The clips are just a simple "U" shaped piece that screws to the plywood backer in the cushion. I am missing one of them but the cushion stays in place pretty well anyway.
I tried to find the same type of clip but they are an odd thing. About the closest thing I've found is an elbow catch for cabinet doors. These can be modified to work with the cushions with a little thought.
The little armrests are fine without clips. They have always stayed in place, even going to Burningman and back over the worst parts of highway 80 didn't jar them loose.
Love those '64s
Good luck,
Rich the Viking
VIKING is offline   Reply With Quote
Old 02-24-2011, 01:54 PM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Cushion clips for 64 overlander goucho???
Greetings Rob!
The brackets on the front lounge on my coach appear to have been modified. When I first purchased the coach, there was a length of elastic through each of the "u" shaped brackets with snaps on each end these snaps were attached to the wooden back of the cushion to keep it in place when underway. When I had Arlene and Henry Fowler (Fowler RV Interiors) refurbish the interior of my coach, they did not reuse the retainers, and I haven't had any particular problems since then. I suspect that the reason that I haven't had problems since refurbishing the interior is that the new cushions are substantially heavier due to much higher-density foam and a very dense upholstery fabric that it takes more to move the cushions.
The armrests in my coach are "tear-shaped", and bracket is essentially a "L" bracket that was carefully bent to make a "u" that just hooks over the "u" bracket that is attached at both ends to the front sidewalls of the coach.
I am afraid that I don't have photos of either of these two items. My schedule has been topsy-turvy, and I don't know just when I will be back to check on the Overlander.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 02-26-2011, 03:02 PM   #4
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
actually, I found the clips in a drawer! I may take some pics for everyone else.
Old 05-14-2011, 09:37 PM   #5
1977 23' Safari
1986 34' Limited
Idaho Falls , Idaho
Would love to see the pics of your found clips! Please post!
Landshark is offline   Reply With Quote
clips, cushions, gaucho
A 1963 Overlander named Moonraker! reinergirl 1960 - 1964 Overlander 702 08-28-2017 11:36 AM
NEEDED: Two front windows for '71 Overlander jesse_kevon Windows, Doors, Locks & Vents 4 05-30-2015 09:26 AM
Window seals and clips for '66-'67 globetrotters Alderman 1965 - 1969 Globetrotter 10 10-16-2014 07:16 PM
From goucho to dinette Seaheart General Interior Topics 8 08-14-2011 08:11 AM
