Old 09-13-2010, 03:04 PM   #1
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
Curved-corner partitions
I'm building new walls for the bathroom and would really like to create rounded corners. Has any one done this?
I found MDF cabinet corners at Tapeease.com
CABINET CORNERS
I thought I could use these with plywood and then veneer the whole thing to give it a finished, unified look.
This seems "easy" in my head, but I wanted to get some advice before I start. I'm sure there are things I am not considering.
If someone has a much simplified idea for this, I am totally open to suggestions.
adwriter73 is offline   Reply With Quote
Old 09-13-2010, 03:26 PM   #2
VIKING's Avatar
Boulder Creek , California
http://www.aitwood.com/images/pdf/CurvedPly2008.pdf
Here's another supplier for components for cabinetry. The mdf corners are weak. if you can use a curved plywood part instead it will be much stronger.
Rich the Viking
VIKING is offline   Reply With Quote
Old 09-13-2010, 06:02 PM   #3
Splitrock's Avatar
Sioux Falls , South Dakota
I think Outwater has curved corners too. I'd probably just use bendable plywood.
Old 09-13-2010, 10:24 PM   #4
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
I don't know that you can bend it to a 90 degree angle, can you?
Old 09-14-2010, 06:37 AM   #5
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Bendable plywood typically comes in 2 thicknesses - 1/8" and 1/4". For tight curves, the 1/8" thick is better. Drawback is bendable plywood is harder to find and comes in fewer species. Big box stores do not carry it. You need a lumberyard or cabinet shop.
Check out: http://www.airforums.com/forums/f91/...-31084-32.html starting post #441. That will give you an idea of how tight you can bend it, and how to construct a frame.
Chris
Old 09-14-2010, 08:14 AM   #6
Splitrock's Avatar
I've just used bendable plywood as a substrate and covered it. The stuff I've used looks like luan. It's easy to find. Reversed tambour works pretty good as a bending substrate too.
Old 09-14-2010, 09:39 AM   #7
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Chris
Hey! That link goes to our '56 Safari restoration thread!
Just to clarify, we didn't end up using bendable plywood - it wouldn't make a tight enough curve to match the existing curves before snapping and breaking. We tried taking it real slow and clamping a little at a time & spraying with water first, but it just wouldn't make the turn. So we built our own corners by layering birch veneer over a 1/4-round frame we built using the holes from our 6" hole-saw pieces, we ended up with the 3" radius we were looking for. We then butted the plywood up to our "corners", sanded the joint smooth and put a finished veneer over the whole thing. It worked great!
Shari
Old 09-14-2010, 10:21 AM   #8
Minno's Avatar
1972 31' Sovereign
Sorry Shari - I could have sworn that you used bendable plywood. Must have been another thread I was following.
Kay & I do refer to your thread a lot, looking for ideas, how you did things, etc. It's one the threads I have bookmarked.
Chris
Old 09-14-2010, 10:35 AM   #9
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
I love this forum
Did anyone else notice stormdeborah's pictures yesterday? She hasn't posted anything but photos so far, but wow!
and now this thread tells me I can get pre-fab curved corners. Sha-Zam! In my day girls were banned from shop classes, but I did pick up a few skills here and there. I don't know that I'll ever do anything but HIRE the cabinetry work I want done for my A/S... but it's nice to think about doing. Perhaps I CAN do a queen to twins conversion in mine. Especially with the nice round corners I can now get if I need them.
The brain is working!
Happy Trails.... Paula
Old 09-14-2010, 10:57 AM   #10
VIKING's Avatar
One more time. If you open the attachment and scroll down to "radius end panels" you will find plywood with various radius' and flat surfaces. The first one on the list is 5/8" thick plywood, 96" long. It has a 26" "extension"(flat area), and then a 3" radius for 90 degrees, and then another 3" extension.
They have a lot of sizes available, and you don't have to make a form or learn how to stack-laminate veneers around one and still be able to clamp them. These are real timesavers.
Rich the Viking
Old 09-14-2010, 01:25 PM   #11
Splitrock's Avatar
These guys make radius corners
http://www.osbornewood.com/product/6986.cfm
This article sort of explains bendable plywood. It's bent cross grain and in my world, it's used as a substrate only and is always covered.
http://www.woodmagazine.com/materials-guide/lumber/sheet-goods-selector/?page=4
Kerfkore makes a bending board that will make a very tight radius.
http://www.premierwood.com/kerfkore-bending-board-c9933.htm
Even with Kerfkore 1/4" the smallest radius is 3.5 inches.
Rockler sells something that looks like Kerfkore but I'm not sure it is.
http://www.rockler.com/product.cfm?page=11206&ne_ppc_id=google&ne_key_id= s3Wqtsu0M&pcrid=543646860&gclid=CLnhsPLNh6QCFSVL5w odH2y0JA
Outwater makes a lot of panel corners and other extrusions
http://www.outwatercatalogs.com/lg_display.cfm/catalog/2010_Master_Catalog/page/9
Old 09-19-2010, 05:56 AM   #12
Arrowstream's Avatar
Columbia , South Carolina
Here's how Spartan Aircraft did it in 1948. They cut top and bottom plates out of 3/4 plywood, added uprights and bent the finish ply over that. For a tighter radius, they used 2x2 finish grade stock on the face frame and rounded the exposed corner. I couldn't get a good picture of that one.
ID:	111205   Click image for larger version
Arrowstream is offline   Reply With Quote
New Partitions - What's the best technique? muddy_hollow Upholstery, Blinds, Walls & Interior Finishes 3 06-25-2008 03:59 AM
Curved window Canstreamer Windows & Screens 0 10-30-2006 03:47 PM
Corner Bath gowyn 2005 and newer - Bambi all models 3 09-09-2006 10:39 AM
Attaching interior partitions to the walls? malconium Cabinets, Counter Tops & Furnishings 13 08-16-2005 06:38 PM
What's around the corner... 53flyingcloud Off Topic Forum 6 12-10-2003 10:20 AM
