Old 09-16-2011, 06:20 PM   #1
1981 31' Excella II
New Market , Alabama
Curtains and those little slidey things
My trailer has the original curtins and I don't know if they will survive the washing process. Even if they do, the little white plastic sliders are breaking and was wondering if there are replacements out there. The curtin system in the back bedroom is rather complicated but it seems to work. I imagine that having a new set of curtins made to fit the OEM sliders would be expensive. There are about a 1000 of those little sliders and the loops that attach them to the curtins.
Perry
Old 09-16-2011, 06:26 PM   #2
2004 25' Safari
1971 27' Overlander
Jourdanton , Texas
Not sure which sliders you need, but Vintage Airstream Supply and Inland RV carry a couple of types of curtain sliders.
Paula
pienjim is online now   Reply With Quote
Old 09-16-2011, 07:06 PM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Curtins and those little slidey things
Greetings Perry!
Most of the curtain sliders are Kirsch products. There are several places where you might find the correct carriers/sliders:
Another option is to check with your local decorating center as they often have access to numerous brands of curtain/drape hanging hardware and can obtain the carriers that you need . . . well equipped fabric/sewing notion stores may also be able to assist in your search.
Good luck with your project!
Kevin
Kevin D. Allen
AIR #827
Old 09-21-2011, 10:19 AM   #4
1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
I just redid the curtains in our 77 Argosy Minuet. A previous owner had tried washing an drying the curtains, but because the fabric was the thermal kind with the thermal rubber backing. The dryer hates this stuff and made the rubber stick to itself so that when I tried to pull them apart the rubber continued to stick and pulled off the fabric leaving great scars that showed through when the curtains are hung. Ugly!!!! These curtains were made by Two owners back and were nice but have suffered. The front curtains were way to wide having way to much fabric in them so they "bunched" to much when they were open all the way. The side curtains were strained tight and hard to get complete closed. My front curtains had the snap slides where a snap that is attached to a fabric tape is cut apart and sewn to the top of the curtain between the pleats. The snap is then snapped into the slider. This type will keep the curtain from sagging but will only fit in a track that accepts the "G" slider. I replaced them with the "G" slider and made the curtain 1' shorter than what I was taking off. I finished the curtain completely without the pleats, pinned the the sliders on and slide everything in place on the track. This allowed my to adjust the depth of the pleat and the amount of fabric which is snapped at the outside edge of the window. I made an even amount of pleat every four inches and sewed the pleat all the way from top to bottom. This helps keep the curtain from ballooning or bulging out in the the middle and keeps the curtain straight and taught. I repeated the process with the side curtain but it uses the "T" slides. Pinning the slide in place and put the curtains up allows you to make adjustment in slider placement and pleat depth. I am very pleased with my new curtains and they cost about a $120 material and slides, snaps, and velcro. The velcro keeps the edges together when the curtains are closed as they do not overlap like house curtains do. I used a cotton duck fabric which was thick enough and heavy enough not to need lining, but I can add lining later as finances allow.
Zittle is offline   Reply With Quote
Old 09-21-2011, 10:33 AM   #5
Perry
Perry.
Your drapes use "T" and "G" shaped curtain tabs.
That shape is determined by looking at the side of the tabs.
Usually, but not always the "T" tabs are on top and the "G" tabs are on the bottom.
Old 09-21-2011, 11:17 AM   #6
1981 31' Excella II
Well you make me some for $120?
Perry
Old 09-21-2011, 11:34 AM   #7
mcair's Avatar
1988 29' Excella
Collinsville , Illinois
Replaced all of the curtains in our 29' excella. Those slides are 7.75 for 25 of them. I managed to salvage a bunch and only order about 3 packages of new ones. The elastic was bad in all of them so I bought a large roll of 1/2" eleastic from Atlanta Thread and re used as many plastic slides as possible. The only ones that were beyond saving were the ones that were exposed to direct sunlight. Much cheaper than buying all new slides.
mcair is offline   Reply With Quote
Old 09-22-2011, 11:55 AM   #8
2006 25' Safari
West Linn , Oregon
Yes, how does one get those " little slidey things?'
And , my trailer needs new curtains!
I would attempt to make them if I had a pattern and those little slidey things- can anyone help??
dmm6 is offline   Reply With Quote
Old 09-22-2011, 12:33 PM   #9
1981 31' Excella II
Andy in the post above probably has them as well as Vintage Trailer Supply.
Perry
Old 09-24-2011, 06:39 PM   #10
Slidey things
The kind of slidey thing you need is determined by how the track is mounted. If the track is mounted so the groove is facing out it takes the G-slides. If the track is mounted so the groove is facing up to down you need the T-slide. The slides on the bottom of my front curtains were all broken from sun deterioration. The snaps and slides were still good and I salvaged them for future use. The side slides were all in tact but the elastic was shot. I saved the slides for emergency replacement but felt new slides with new curtains went together.
