Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Upholstery, Blinds, Walls & Interior Finishes
Old 09-26-2009, 12:25 AM   #1
H2K
Profile:  1991 29' Excella
Sidney , Ohio
Curtains
Has anyone tried to dye their curtains? We recently purchased a 1991 airstream. The curtains have a "mint green" tint but seem to be in good condition otherwise. Any thoughts?
H2K is online now   Reply With Quote
Old 09-26-2009, 05:50 AM   #2
otek800's Avatar
Profile:  1982 34' Limited
colony , Kansas
Give it a try on one of the smaller curtians...
otek800 is offline   Reply With Quote
Old 09-26-2009, 06:38 AM   #3
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 156
Curtains
Greetings H2K!
Welcome to the Forums and the world of Airstream ownership!
There are two problems that may crop up with trying to dye draperies typically found in an Airstrea. First, the lining probably will react to the dye much differently than the face fabric . . . this difference may or may not be obejctionable when viewed from outside the coach. For many colors, you will be asked to process the fabric through a dye-release bath followed by a wash to remove as much of the original color as possible. If the drapes are original -- or even 10 years old or older and have been exposed to ultraviolet energy for much of that time, by the time the dyeing process is complete the fabric is likely to be showing evidence of degradation/breakdown. Trying the dye process on one pair of drapes would identify the probable extent of either problem if all of the drapes are exposed to the same process.
Good luck with your research and project!
Kevin
Kevin D. Allen
AIR #827
Curtains Jim Kinsey Upholstery, Blinds, Walls & Interior Finishes 21 10-20-2007 10:24 PM
Curtains again! RevBec Upholstery, Blinds, Walls & Interior Finishes 7 07-26-2005 07:02 AM
Help with curtains PLEASE RiskIt Upholstery, Blinds, Walls & Interior Finishes 15 11-25-2004 11:24 AM
Curtains Nadie Upholstery, Blinds, Walls & Interior Finishes 1 09-30-2004 06:02 AM
Curtains M&J Siegford Parts Archive 5 05-31-2004 09:01 AM
