Old 03-23-2011, 05:14 PM   #1
1969 25' Tradewind
Berkley , Massachusetts
Curtain tracks..What's the hardware used?
hi there
am working on making new curtains/drapes for the '69 TW..here are the tracks..does anyone know what hardware is used to hang them ? I have nothing to go by except for the pieces still hanging..thank you for your help!
(photos are: bottom track, top tracks, and the side windows top and bottom..)
(also, what goes into those pieces from the curtains would be helpful! )
ID:	125157   Click image for larger version
ID:	125159   Click image for larger version
michelle50 is offline   Reply With Quote
Old 03-23-2011, 05:41 PM   #2
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Hi Michelle50,
I believe standard curtain hooks are used on the front window. The side windows use plastic slides that are available at www.vintagetrailersupply.com. You may have to call them with some measurements if you're not sure from the photos on their website.
Colin
Colin H is offline   Reply With Quote
Old 03-23-2011, 05:48 PM   #3
RGates
Randy Gates's Avatar
1968 20' Globetrotter
Thousand Oaks , California
Curtain Tracks
Hi,
I have a 1968 Globetrotter. They are sew-on curtain tracks that are spaced and sewn onto the curtain and slide in the aluminum tracks. See the Vintageairstream/archives site for numerous examples. Get a few bags from VTS. Happy motoring!
Randy
Randy Gates is offline   Reply With Quote
Old 03-23-2011, 06:13 PM   #4
Originally Posted by michelle50 View Post
hi there
Your Airstream was not built with the drape tracks that you show in your photo.
Someone installed those, after the fact, probably because Airstream used spring loaded drape tabs, in 1969 only, that today cost over $2.00 each.
Most owners upgrade to the drape track that use the "T" and "G" tabs.
Airstream has used the "T" and "G" track for over 35 years, up to and including today's models.
Old 08-10-2011, 07:07 AM   #5
1969 25' Tradewind
Augusta , Georgia
Where do you get these spring loaded drape tabs and what do they look like? I think that may be what I need for our 1969 Tradewind for all the windows except the fron curved windows as it has a gold bar that has a deep track on it.....
Elizabeth Curry
da_lizard is offline   Reply With Quote
Old 08-10-2011, 07:18 AM   #6
Elizabeth Curry
You may wish to upgrade the drape tracks in your 69.
The spring loaded drape tabs for the 69's cost over $2.00 each.
They are only available from Airstream or a dealer.
Placement of lower curtain tracks over back gaucho 73 Tradewind. constructor Upholstery, Blinds, Walls & Interior Finishes 1 03-17-2011 06:22 AM
Original Curtain Track for '58? mello mike Upholstery, Blinds, Walls & Interior Finishes 3 03-11-2011 08:48 PM
Original Shower Curtain for 1967? star kitty General Interior Topics 3 02-19-2011 08:49 PM
Need curtain track photos circa '79 blickcd Upholstery, Blinds, Walls & Interior Finishes 5 01-11-2011 05:06 PM
