I found some great fabric the other day and it is exactly what I wanted for my curtains. I want to get started but the small rubbery curtain tabs confuse me. Do I construct the curtains first then attach them to the tabs or do I incorporate the tabs into the curtains within the seams? I hope my question makes sense!
Depends on what kind of tabs you're referring to, sounds like you have the flat kind? Those would be sewn to the curtain either during or after.
__________________ AIR 12256 Currently Looking 2001 Dodge Ram 1500 2001 Honda XR650R Currently Looking...for an Avion Truck Camper (or a Classic Argosy MoHo)
Does this help, we made the curtains then sewed on the tabs.
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281 www.balrgn.com
I'll be doing the same thing this weekend. I think they should be sewn on after. I don't think the needle of the machine can be selective enough to put it self in those little spaces without cracking the plastic tab.
Those are the same as the ones on our shower curtain. They had needle holes in them from the old curtain which was missing, so I sewed them on with my machine. No problem ~
Good luck with the curtain projects, it's a big task...I was scared to start but once I was down very satisfied with the results.
Shari
If you have a small version of an awning rail as a curtain track and it's riveted to the wall, then you probably want to use the elastic type "G"-Tabs.
These are available from any AS dealer and not to be cofused with the 'T"- Tabs which are commonly available but only used for overhead track (i.e. in a valance, not on the wall). They'll run you about 40 cents /tab.
Murray
AIR #189
"If aluminum isn't magnetic- why am I so attracted to to it?"
We ended up sewing the tabs into part of the pleat with the machine, and then finished the pleat. My mother was able to program the distance needed to cover and pop in a hole in the webbing in her super cool computerized machine.
