Old 09-12-2005, 11:25 AM   #1
Curtain Questions
I'm going to do my curtains myself as soon as I find the right material--I've made curtains before so basically know what to do, but I have a question about what the hooks look like for the 65 Safaris?
there is a track over the windows with plastic thingys that have a small hook eye type thing on the bottom--I assume some kind of a hook fits in there--the owners had just store bought curtains with the metal hooks with a sharp bottom section that goes into the fabric like a pin--but these seemed too big for the original tracks and didn't work very well.
If I know what they look like i can go to the fabric district in NYC and get them for a good price rather than order from an RV supplier.
thanks--Zoe
zoeb nj is offline   Reply With Quote
Old 09-12-2005, 11:53 AM   #2
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Jackson Center
Not sure if the hooks are the same for vintage, but when I was at Jackson Center this spring, I spotted the hangers for new curtains, they are a piece of elastic about 1/2 inch wide sewn to a sort of u-shaped plastic. The plastic slides down the center of a track mounted above and below the windows. I think they were $.10 each - but you need a load of them! Probably 1 every 4 inches top and bottom. On my new unit the shower curtain is hung with the same hook as the other curtain.
Tin Liz
Old 09-13-2005, 09:27 AM   #3
thanks Tin Liz--I don't think that's what i need--there's only a track on the top edge--and then you snap the curtains on the side to hold them secure.
I just emailed a guy who's selling the clips that go in the tracks on ebay to see if he knew but his trailer didn't have curtains when he got it. Oh, well.
Zoe
Old 09-13-2005, 09:41 AM   #4
Helmi's Avatar
1963 22' Safari
1963 19' Globetrotter
Montreal , Quebec
curtain hook question
I just made curtains for our 63 Safari. Instead of buying special hooks that cost a fortune, I used old buttons that were able to slide through the track. I sewed the button to the inside top hem of the curtain and slid it into the track.
Helmi is offline   Reply With Quote
Old 09-13-2005, 11:42 AM   #5
aren't you the clever one!
is this what you did-- used buttons with a shank--the flat button part slid in the track and the shank part you sewd to the curtain?
I love it!
Old 09-13-2005, 11:46 AM   #6
curtain width yardage--what did you use?
what looks the nicest on a trailer? I don't want it to look bunchy, but I don't want skimpy either. I was going to do 2x the width, but the curtain book I'm using for advice says 2 1/4x.
Old 09-13-2005, 11:53 AM   #7
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Here's a link to my webpage that shows the curtains I made...I used 2-1/2 widths.
Good luck with whatever you decide to do ~
Shari
Old 09-13-2005, 12:08 PM   #8
InsideOut's Avatar
1956 22' Safari
Images: 108
Here's a sketch of 'the button solution' that I did some time ago, post #9. It seemed to work very well in the trailer I saw it in.
Shari
Old 09-13-2005, 12:15 PM   #9
1964 19' Globetrotter
charlotte , North Carolina
If all else fails call Frank.
http://www.jpadrapes.com/
Obviously you dont need the drapes but he may be able to
offer some suggestions from his wealth of knowledge.
chikagurl is offline   Reply With Quote
Old 09-13-2005, 12:55 PM   #10
wow, Shari--that link gave me exactly what I needed--your curtains look beautiful--and those hooks answer another question I had.
shari said--
There were these suspicious snaps inside the shower stall...my guess is that they were to wrap the curtain around to better protect the sink area from overspray...we have removed them for now.
I can actually answer this--amazing! the shower curtain was still in our Safari--your guess is correct--there's snap tape sewn along the curtain edge which snaps into the wall--I figure eventually I'll re-se the tape on a new shower curtain.
Zoe
Old 09-13-2005, 01:01 PM   #11
InsideOut's Avatar
1956 22' Safari
Images: 108
Glad you found the link to be helpful.
I have actually seen the wrap around shower curtain since I built that webpage, I actually like the set-up I have now and won't be going back to the origianl wrap around style, we don't need it, ours works fine.
Shari
Old 09-13-2005, 04:50 PM   #12
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
Shari, your curtains look great. Good idea on the shower curtain. I like the bubble design too. But the biggest hit of all is your website background!! I adore it!! Is it a laminate design?
Shari
Caroljb
photography
wheel interested is offline   Reply With Quote
Old 09-13-2005, 06:47 PM   #13
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Zoe!
If your '64 uses the same track and fastening mechanism as my '64 Overlander, new glides are available from Kirsch Drapery. A local custom drapery shop was able to order a few replacements for me from their Kirsch catalog last summer -- since I have just moved, I can't seem to find the package with the identification information.
Good luck with your search!
Kevin
Kevin D. Allen
AIR #827
Old 09-13-2005, 08:02 PM   #14
InsideOut's Avatar
1956 22' Safari
Images: 108
Thanks!
No it's not a laminate...just a graphic .jpg I found.
Shari
'85-34ft Sovereign City Water Hook up E&T Stutts 1984 - 1989 Sovereign 1 10-31-2002 06:31 PM
shower curtains gmc70 Upholstery, Blinds, Walls & Interior Finishes 12 10-20-2002 02:25 AM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
shower curtain "cap like" grommets Neenm Upholstery, Blinds, Walls & Interior Finishes 0 08-03-2002 02:04 PM
Shower curtain Zed2 Upholstery, Blinds, Walls & Interior Finishes 1 06-24-2002 09:03 PM
