Old 05-28-2006, 11:37 PM   #1
Austin , Central Texas
Curtain end stops
At the end of the curtain track, there are end caps (stops) that prevent the clips from sliding off the end. These are screwed to the track.
I had one break this weekend. I have been surfing to fine replacements with no luck. Any suggestions where to find a replacement?
FlyFishInn is offline   Reply With Quote
Old 05-29-2006, 12:00 AM   #2
Angel73's Avatar
1975 31' Sovereign
Woodlawn , Tennessee
Images: 65
Send a message via Yahoo to Angel73
I know the feeling
Are you talking about the yellow pastic end caps?Am not sure if you can still get them new but try this place. http://www.colawrvsalvage.com/ or this https://www.rvsurplussalvage.com/
The Clark Family
Angel73 is offline   Reply With Quote
Old 05-29-2006, 12:08 AM   #3
Mad1
1989 29' Excella
Dallas , Texas
I just put a small stainless steel screw into the track as a replacement end stop. Don't put it in so tight as to distort the track.
madrone is offline   Reply With Quote
Old 05-29-2006, 03:45 PM   #4
Screws have it...
From what I gather, use a small stainless screw and keep your eyes out for replacements if they come along. Thanks.
Old 05-29-2006, 04:25 PM   #5
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
do you mean these?
Name:	IMG_5383 curtain ends-s.jpg
Old 05-29-2006, 04:38 PM   #6
Not quite the same
Mine have a more rounded edge.
Thanks. The search goes on...
Old 05-29-2006, 06:45 PM   #7
Cracker's Avatar
Pittsfield , Maine
End Caps
Try the mothership (Airstream) in Ohio. I bought several there last summer.
Cracker
Cracker is offline   Reply With Quote
Old 05-29-2006, 07:49 PM   #8
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
They use those on the curved track sections in the front and back. My dealer had these in stock when one broke last year.
Interestingly enough on my 2004 with the straight track sections, they just place a screw at the end of the track with the edge of the head just over the track end to keep things from sliding off.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 08-08-2011, 06:31 PM   #9
1976 25' Caravanner
Perry , Utah
I need those!!
Originally Posted by Zeppelinium View Post
do you mean these?
Attachment 21719
Yes Yes.. I need those.. A set.. Where do I find them? I hate to revive an old thread but I've been google image searching and this is the only hit I've found.
NeoCole is offline   Reply With Quote
Old 08-08-2011, 10:00 PM   #10
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Those used in newer Aristreams are shown below. You can get them at an Airstream repair center, I know. We bought some at Oasis RV in Tucson. There are two differnt caps for opposite ends of a track.
If you can't find them you can screw a short screw into the end of the track to keep the glides from coming off until you find the end caps. Be sure not to put a screw in that's too big or it will deform the track.
Name:	Curtain Track End-Cap_Sm.jpg
TB & Greg and Abbey Schnauzer
#3954
Old 08-08-2011, 10:24 PM   #11
aftermath's Avatar
Spokane , Washington
My dealer right in town carries them. I am sure you can get them from any dealer.
aftermath is offline   Reply With Quote
Old 08-08-2011, 10:35 PM   #12
UAPachyderm's Avatar
2004 28' International CCD
Birmingham , Alabama
Here are the Airstream part numbers for the newer type...
6. 200785 End, curtain track, LH
7. 200784 End, curtain track, RH
UAPachyderm is offline   Reply With Quote
Old 08-09-2011, 09:50 AM   #13
1976 25' Caravanner
Perry , Utah
Curtain Track End LH off White 200785 [200785] - $1.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone! Yeah.. I saw these.. They're idy bitty. My ends hold up the whole curtain rod and have busted on the top mount. I have a 1976 Airstream Caravanner
Old 08-09-2011, 09:51 AM   #14
1976 25' Caravanner
Perry , Utah
I need the huge ones posted by Zeppelinium
Shower door. Has anyone put one on a 1987 345 or similar airstream with curtain? MacInDaBox Airstream Motorhome Forums 2 05-17-2007 12:06 PM
Saggy Bottom ( rear end ) smily Repairing/Replacing Floor &/or Frame 127 10-01-2006 08:28 PM
shower curtain "cap like" grommets Neenm Upholstery, Blinds, Walls & Interior Finishes 0 08-03-2002 02:04 PM
End Joints in New Floor melprice Floor Finishes 3 07-12-2002 11:16 AM
Shower curtain Zed2 Upholstery, Blinds, Walls & Interior Finishes 1 06-24-2002 09:03 PM
