I had hairline cracks in the upper corners of the rear cap on each side of the cabinet.
Remove the overhead cabinet and fiberglass the cracks from behind. If you support things so the crack is minimal while glassing i would not attempt to do any more on the outside because of color matching.
I had to cut a wedge section in the sheet metal ends of the cabinet to get it back in place once the fiberglass set up. I cut and installed a false panel at each end to cover the cut metal.
2004 Excursion 4x4
