Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Upholstery, Blinds, Walls & Interior Finishes
Old 04-07-2007, 01:34 PM   #43
Shacksman
Shacksman's Avatar
Profile:  1967 22' Safari
1960 28' Ambassador
Avonton , Ontario
Originally Posted by Safari Tim
That looks sharp Doug.
I assume you're putting it across the front. So it will have to be away from the front about 16" or so. That would actually work out nicely for the recliner. I also like the drop down table in the center.
I'd like to see some inside shots of your Ambassador! (Do you have a fold away bunk? I'm looking for detailed photos and measurements so I can build one
If I use it it will fit across the front. We have no one that will be travelling with us so we don't need extra beds. Anyway I can sleep in the recliner at home just fine. I am way behind you on finishing as we took off for the winter and headed south. I've got 2 finished trailers so I can take time out from this one . We don't have bunks, you'll have to see Rob for that. He just brought home his remade bunks. Check out his blog.
Doug
WBCCI #3327 - VAC
73 Argosy
67 Safari
60 Ambassador Int.
Shacksman is online now   Reply With Quote
Old 04-11-2007, 12:29 PM   #44
kincaidjesse
kincaidjesse's Avatar
Profile:  1966 28' Ambassador
Here , Illinois
Hello:
This is just a short test. Yesterday, nothing went through. More if it does!
kincaidjesse is offline   Reply With Quote
Old 04-11-2007, 12:38 PM   #45
kincaidjesse
Here , Illinois
OK. Working. Don't know what I did yesterday.
I think you can have both a couch and a bed. I have a 1966 Ambassador and I had to replace the couch/bed. The area looks like yours but the cabinets (bed frame) and shelf under the window were present.
I had a mattress custom made to fit the area for about $120. Fortunately, I had the frames for the arm rests on the ends - they were just bedraggled. So, I purchased heavy duty oil cloth (marine quality) from JoAnne's Fabrics, took the mattress, the arm rests and a heavy foam rectangle for the back rest to an Amish boat canvas upholsterer and had them upholster all of that, plus the mattress for the 2nd bed. It just wipes off - no dirt, no pet fur. The table on the end which folds up was present.
I have photos for you, if you like. I haven't figured out how to insert them.
Old 04-11-2007, 12:47 PM   #46
kincaidjesse
Here , Illinois
One more thought. I would not recommend foam. Since the Hurricane, the price of foam has shot through the roof. Mattress factories, like The Denver Mattress Factory, etc. actually do a great custom job for a fraction of the price of foam. Foam needs to be pretty thick to hold up to pressure and weight. I will try to figure out photo uploads or I could email mine if they would help at all. Good luck!
Old 04-16-2007, 05:54 AM   #47
PizzaChop
PizzaChop's Avatar
Profile:  1973 31' Sovereign
Danielsville , Georgia
Images: 197
Nearly Finished Dinette Pics
Okay, probably last pic of the dinette before I post project completion pics under my "photos" section.
Finally finished trimming out all the frames as well as adding a small piece of molding around the top to support the table in the bed position. Stain and finish will wait till after the Springstream Rally this weekend.
Tables were constructed with 1/4" luan with a 1" plywood frame underneath. (each table weighs 11 lbs). They will be clasped together using window latches.
Foam is "wrapped" for now. My wife will sew covers with piping later this spring.
Name:	Dinette 005 webcopy.jpg
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Couch option Pahaska 2003 International 10 07-14-2005 12:05 AM
New Intl Floorplan RoadKingMoe 2003 International 41 03-02-2003 05:10 PM
Questions about the 2003 International. Would you buy again/fair price. Debbie 2003 International 29 11-07-2002 04:11 PM
Will this couch fit my trailer?? JohnGalt48 General Interior Topics 4 08-07-2002 06:38 PM
front couch for 31 soverign center bath jim c taylor General Interior Topics 0 04-12-2002 03:58 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
U2 Forums
