Old 01-26-2015, 08:30 AM   #1
1999 28' Excella
New Orleans , Louisiana
Cosmetic or worse?
Guess thru regular door usage this happened. We are full-timers. I was thinking of a stainless steel back splash that would cover it since it is right by the stove.
What would you do?
badkat is offline   Reply With Quote
Old 01-26-2015, 07:09 PM   #2
1999 28' Excella
Well, must be cosmetic. I will post pics when I put in the stainless steel back splash.
Old 01-26-2015, 07:17 PM   #3
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
I don't have any wisdom regarding the severity, but I had to cover something up. Our PO hot-glued (what's up with that?) a picture on the wall behind the stove, adjacent to the entry door. Vibration shook it loose and it pulled the vinyl off of the substrate in several places.
We found a stainless mosaic at Lowes: Shop Stainless Steel Metal Mosaic Subway Wall Tile (Common: 12-in x 12-in; Actual: 9.76-in x 11.73-in) at Lowes.com
Ran it from the countertop to just above the vent fan and from the door to about half way to the sink. Looks great!
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Al and Missy is online now   Reply With Quote
Old 01-26-2015, 08:30 PM   #4
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Not sure what I'm looking at but it looks like the area where a previous owner may have made a patch when he had to get to the back side of the door hinge to tighten the bolts/nuts. Check that the door hinges are tight to the shell.
Doug and Cheryl
Old 01-26-2015, 09:37 PM   #5
1974 Argosy 20
Kooskia , Idaho
Looks to me like what dkottum (doug) says, a cut to get access to the door hinge bolts.
Old 01-27-2015, 12:00 AM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
After ensuring the hinges are tight, go to a 'sheet metal shop' and have them make a 'backsplash' for you.. take it all the way to the door trim to cover the area. You MAY need to get back in there some day...
Peace and Blessings..
Channing
WBCCI# 30676
Old 01-27-2015, 08:10 AM   #7
1999 28' Excella
Gosh you guys are good. It is right at the hinge and looks like a strip of wallpaper was replaced. Well I wanted a stainless back splash so guess I get one now. Thanks again!
Old 01-27-2015, 12:02 PM   #8
Minooka , Illinois
Hello-
I am new to this forum. I hope I am not messing up the topic. But my question is can you walk on to of an airstream roof to check ac or vents?
Thank you in advance..
Deerhunter1 is offline   Reply With Quote
Old 01-27-2015, 03:21 PM   #9
1999 28' Excella
Oh my gosh..I would not!! You have to stay where the ribs are.
Old 01-27-2015, 06:24 PM   #10
Ron A's Avatar
2018 23' Flying Cloud
Huntsville , Alabama
Deerhunter1 good question. I too am new to airstream, wondered the best way you might check on the a/c unit, wax, etc. on the roof. Wondered if the roof would hold your weight. I hope someone can share their tricks for roof maintenance and upkeep.
Ron
Ron
Ron A is offline   Reply With Quote
Old 01-27-2015, 06:27 PM   #11
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
You guys just need to do a search. Several long threads with experts weighing in.
Old 03-01-2016, 06:55 PM   #12
Ohiobrits's Avatar
2015 27' FB International
Howard , Ohio
Originally Posted by Deerhunter1 View Post
Hello-
Try this.
2015 27FB International Signature "Danielle"
ProPride / 16" wheels / 600W solar / 864 AHr Lithium
Victron MultiPlus Inverter / BlueSolar / ColorControlGX / BMV 702
Porsche Cayenne Diesel
Ohiobrits is offline   Reply With Quote
Aluminum Duct Tape Cosmetic Usage withidl Clearcoat, Exterior Paint & Trim 6 12-05-2010 08:41 PM
Any special kind of Airstream Repair, cosmetic or mechanical.... Dureedesign General Repair Forum 5 06-26-2007 03:49 PM
Cosmetic Window Repair C-dink Windows & Screens 2 02-25-2006 05:38 PM
If you think it is bad, it is probably worse j54mark General Repair Forum 5 09-27-2003 05:54 PM
Fleas and worse cjholloway The Pet Forum 4 08-09-2003 05:39 PM
