Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Upholstery, Blinds, Walls & Interior Finishes
User Name
Password
Portal Register FAQ Members List Rally Calendar Chat Room Mark Forums Read
Welcome to the AIRForums.com the community where Airstream enthusiasts meet online. Our members have contributed over 30,000 pages of information about Airstream Trailers & Motorhomes.
You are currently viewing our site as a guest which allows you to read most all of our content. By joining our community (For FREE) you will have access to participate in the discussions, post new topics, connect and communicate with other members, respond to polls, upload your own photos, post classified ads and access many other special features.
Registration is fast, simple and absolutely FREE so please join our community today!
Click Here to Register!
- Monthly Newsletter
Old 06-11-2007, 08:07 PM
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Lower Middle, Tennessee
Question Corner full size bed
I have the streetside corner full size bed which measures 75" long by 54" wide not counting the rear curvature of the trailer. There are two sheet of lightweight veneer type sheeting which is screwed into the aluminum frame running perpendicular to the side of the trailer. The PO placed another thin sheet of plywood over this which is only 48" wide and maybe 70" long in addition to placing a piece of slippery plastic sheeting on top of that. I guess he was looking for additional support with the extra plywood and using the plastic as a vapor barrier or to protect the mattress.
My question is, can I remove the original two thin vaneer sheets with slightly thicker plywood? My reason is that I want to cut a round hole in it so that I can mount an 8" boat deck screw lid to access the bypass valves on my water heater underneath? I currently have to squeeze through the rear compartment to reach the valves and I'm real close to getting stuck. Could you see the headlines: "Airstream owner suffocates in side access compartment!" I realize I could just lay a piece of plexiglass over the hole but want a white ring clear center deck access to make it right. What do you think?
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Get rid of these ads... register today, it's FREE
Old 06-11-2007, 08:27 PM
Tim A.
Profile:  2002 19' Bambi
Lafayette, California
Our 2002 19' Bambi also has the bed located where yours is and has two pieces of plywood supporting the mattress. That plywood is not very thick, but is good quality, void-free plywood. One of the pieces has a 5"-6" (if I remember the size correctly) access hole for the water heater valves and that hole is simply open. The mattress bridges it without problem. In other words, you might not need the deck access plate unless you do not want the open hole.
Getting good, void-free plywood is not easy. One possibility is so-called Baltic birch plywood. It commonly comes in 5'x5' sheets and most of what is sold today has nominally interior glue. Your use is interior so that should not be a problem and the glue is good and the plywood is truly void-free.
vB code is On
Pingbacks are On
Full Size Queen Bed... Chopper Cabinets, Counter Tops & Furnishings 2 09-24-2006 07:06 PM
1985 Sovereign 25' with side bath, corner bed tubbinator Member Introductions 6 07-09-2006 12:44 PM
Twin rear beds DClark General Interior Topics 15 11-24-2002 08:49 PM
Bunks Bugs General Interior Topics 9 11-17-2002 06:43 PM
Center folding bed attachment uwe Cabinets, Counter Tops & Furnishings 6 06-30-2002 08:01 PM
Powered by vBadvanced CMPS v2.1.0
Powered by vBulletin® Version 3.5.8
SEO by vBSEO 3.0.0
Airstream is a registered trademark of Airstream Inc. All rights reserved.
Airstream trademark used under license to Social Knowledge LLC.
Wikipedia about Airstream - Airstream Central - Airstream Photos
