Old 10-09-2010, 08:31 PM   #1
2008 23' Safari FB SE
Boulder , Colorado
Cleaning interior aluminum?
Hi everyone -
We are prepping our unit for winter and would like to clean the interior fully. What is recommended for cleaning the interior aluminum above the sink area and walls ('08 FB SE.)
Thanks!
Sandy
bonginator is offline   Reply With Quote
Old 10-09-2010, 10:04 PM   #2
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
Originally Posted by bonginator View Post
Hi everyone -
Thanks!
Sandy
Sandy....We use Walbernize RV Seal Wax on both the exterior and interior aluminum panels of our 2007 25'FB. Seems like it does a good job and doesn't remove the clear coat finish on the panels.
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Old 10-09-2010, 10:11 PM   #3
tpi
Trabuco Canyon , California
If its not real dirty, just dusty, waterspots or fingerprints- I use Meguiars Quik Detail.
tpi is offline   Reply With Quote
Old 10-10-2010, 07:56 AM   #4
Boulder , Colorado
cleaning interior
Thanks for the suggestions. This really helps!
Old 10-10-2010, 08:41 AM   #5
_
have you checked the owners manual?
section D is very detailed on ext care and section E covers interior cleaning (all the surfaces/fabrics)...
"Trailers with aluminum interior skin (Upgrade package)
should follow the same cleaning instructions
detailed in the Exterior section of this manual for the exterior skin."
so IF u need to remove tar, splattered bugs, acid rain, salt, tree sap/leaves and so on...
follow the same steps as cleaning the OUTSIDE.
the inner skin is the SAME STUFF as the outer skin, including the clearcoat.
here is what ALCOA recommends for cleaning...
http://www.airforums.com/forums/f441...oat-18760.html
i am not a fan of walb' for newer streams inside or outside, and there are excellent HOW 2 clean threads like this...
http://www.airforums.com/forums/f441...ize-31480.html
What is recommended for cleaning the interior aluminum above the sink area and walls...
there is an older/longer thread on this topic (interior alum care) here...
http://www.airforums.com/forums/f46/...ior-20385.html
given the unit is headed for storage this is LESS of a concern, but for everyday use consider that...
NONE of the common exterior auto care products are SAFE around eating or food prep areas
__________
why not just use water, a few drops of dish soap, microfiber towel and other simple products?
go back and read the instructions from alcoa.
IF u plan on WAXING the interior skin, any mild NON abrasive wax will work fine.
detailing sprays are probably ALL that is needed for shine in the NON galley areas.
cheers
2air'
Old 10-10-2010, 09:37 AM   #6
After you clean that metal, you can apply some "Future Floor Acrylic" which is a floor wax.
If it's good enough to walk on, it will certainly do a great job keeping the aluminum looking great, permanently.
That same floor wax, can be applied to the vinyl covered walls as well. It will not only protect the vinyl, it will also add a nice sheen to the appearance.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-15-2010, 09:54 PM   #7
Boulder , Colorado
Thanks everyone - great input. I am going to do my cleaning this weekend so this was very helpful!
Sandy
Cleaning Agent (Aluminum Exterior) Cat Cleaning, Stripping & Polishing 21 07-24-2020 08:44 PM
Cleaning/Waxing Aluminum Interior Toasty's Dad General Interior Topics 25 07-27-2015 09:20 AM
Brushed aluminum cleaning FreshAir Cleaning, Stripping & Polishing 6 09-07-2010 11:29 AM
Cleaning Anodized Aluminum - Silver Streak jayk47 Cleaning, Stripping & Polishing 11 04-11-2008 09:51 AM
Advice - cleaning aluminum extrusion CampbellMcCa Clearcoat, Exterior Paint & Trim 3 05-18-2007 02:19 PM
