Old 11-18-2012, 06:31 PM   #1
1994 30' Excella
Courtenay , British Columbia
Cleaning fuzzy interior wall panels
New member: have fuzzy interior panels that desperately need cleaning after we removed couch, and cabinet for a reno. Has anyone been successful at cleaning them; if not how difficult is it to remove them and replace with?
thefroghouse is offline   Reply With Quote
Old 11-18-2012, 06:54 PM   #2
Alumaholic's Avatar
2019 27' Flying Cloud
Albuquerque , New Mexico
Images: 36
I use my carpet cleaner that I purchased just for my Airstream. (Bissell 1425 Little Green Machine ProHeat Turbobrush Compact Multi-Purpose Cleaner)
Ken L
2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow
Four Corners Unit WBCCI #5783
Alumaholic is offline   Reply With Quote
Old 11-18-2012, 06:56 PM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I tried it on a 94 Sovereign. It was not successful. I even called in a professional steam cleaning company. To remove and replace all the hull liner covered panels would be a major, but possible, job.
Old 11-18-2012, 07:23 PM   #4
moderator
Airslide's Avatar
2016 27' International
Wilton , California
Images: 50
I was successful with cleaning the mousefur recently. It never seems to work out when you clean in place due to the rivet or aluminum panel dust being pulled through the material. We decided to pull the material loose from the bottom and allow it to peel free from the lower wall. Once we had it partially loose I used a woolite cleaner in a bucket and a soft brush to clean all the stains. I placed a fan in the trailer with my dehumidifier so the panels would be nice and dry. Becareful not to stretch the panels when cleaning so everything goes back in place. when it was dry I used the upolstery spray glue to tack it back in place. It wasnt perfect as if it was replaced but it sure looked good when it was done.
Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 11-19-2012, 01:38 PM   #5
1994 30' Excella
Thanks for the help in cleaning fuzzy walls.
Old 11-19-2012, 02:57 PM   #6
dznf0g's Avatar
Oswego , Illinois
Another member uses Oxyclean in a spray bottle for the rivet dust. I think a combination of carpet cleaning maching and hand Oxyclean would do the trick.
-Rich-
Old 11-19-2012, 03:19 PM   #7
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I removed the fuzzy stuff in front and did not replace it on our 25'. Not much of it shows and the wall was painted the same under the fuzzy as above. I like it better this way.
Old 02-04-2013, 08:26 PM   #8
1994 30' Excella
the frog house has success. I went with "Oxy Clean" then followed up with Sudsy Ammonia and a wet/dry vac. The panels came up really well. Since then I've investigated a spray fabric dye which I may try if the end result is not to my liking.
Deb
Dry Cleaning 02 Safari Curtains? Ridgerunner3 Upholstery, Blinds, Walls & Interior Finishes 3 12-02-2011 03:00 PM
Solar Panels Provide Shade - Fact or Fiction? UAPachyderm Boondocking 11 08-21-2011 03:18 PM
Repair to Interior Door Panels of Dometic M 70b 69AirDream Refrigerators 13 04-01-2011 07:15 AM
