Old 10-03-2012, 07:02 PM   #1
1997 25' Safari
Elgin , Arizona
Cleaning carpeted walls
Our 97 safari has (standard) white carpet material on a number of wall surfaces. Best way to clean? thanks
caseypris is offline   Reply With Quote
Old 10-03-2012, 08:55 PM   #2
RichardT's Avatar
I like the Bissell Little green machine. Little Green (R) Deep Cleaner I have had one for years and they work great with the cleaners available for them. Get one at Walmart
RichardT is offline   Reply With Quote
Old 10-03-2012, 10:19 PM   #3
Bob Thompson's Avatar
Corpus Christi , Texas
Images: 67
I mix up some Oxy-Clean, put it in spray bottles and spray away, starting at the top and working my way down. With aggressive spraying, you can actually see the dirt and dust be loosened and washed downhill. The cleaning solution will try to migrate down to the floor. When it gets there or gets close, I use my wet/dry shop vac to suck it up. Actually works pretty well. I've even been able to remove most aluminum dust stains.
So Long!
Bob Thompson is offline   Reply With Quote
Old 10-04-2012, 06:23 AM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I've never tried it on carpeted walls, but to avoid costly carpet-cleaning at home, I just use ordinary laundry detergent to clean my carpets.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-04-2012, 10:36 AM   #5
2005 28' Safari
saline , Michigan
Thanks for that tip Bob Thompson, I will try that on mine. I've used Resolve with great sucess except the aluminum dust you refer to.
Kosm1o is offline   Reply With Quote
Old 10-04-2012, 10:47 AM   #6
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I have had good results with this Folex Instant Carpet Spot Remover removes spots and stains
I found it at Lowes and Target
Alan
Old 10-04-2012, 10:48 AM   #7
Lily&Me's Avatar
Normal , Illinois
Oxyclean, used lightly and rinsed well, will clean, brighten and destain anything.
Maggie
Old 10-04-2012, 11:11 AM   #8
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
Factory service recommended SD20. It has a lot of terrific uses. Also works nicely on drapery spots. K2R spot lifter also works well dab on and brush off when dry. Try to avoid saturating the material so as not to cause leaching from behind the fabric.
https://store.airstream.com/product_...products_id=79
Caroljb
photography
wheel interested is offline   Reply With Quote
Old 10-07-2012, 09:04 PM   #9
1997 25' Safari
Elgin , Arizona
Thanks!
Old 10-23-2012, 08:09 PM   #10
Jim J's Avatar
2014 30' Flying Cloud
Images: 117
I use this method as well. You can make your own cleaning solution from oxyclean and water.
Jim J is offline   Reply With Quote
Old 10-23-2012, 09:04 PM   #11
ddruker's Avatar
2000 27' Safari
Palo Alto , California
Step 1 - Spray on carpet cleaning solution mixed with hot water.
Step 2 - Rub around vigorously with a clean cloth soaked in same solution
Step 3 - Vacuum with shop Vac
Step 4 - Spray on clean cool water
Step 5 - Run around vigorously again
Step 6 - Vacuum with shop Vac
Do one section at a time. You would be amazed how much dirt comes out - the liquid the shop vac sucked out was disgusting.
If I had a steam cleaner machine with hand attachment, I would just use that.
- Dan
1999 27' Safari + 2011 Mercedes GL 350 Turbo-diesel
ddruker is offline   Reply With Quote
