Old 07-08-2010, 05:14 PM   #1
1968 22' Safari
Waitsfield , Vermont
Clay or stucco walls
I'm restoring a 68 Safari and am thinking about doing clay or stucco walls (probably stucco). Does anyone have experience using either of these?
68vtsafari is offline   Reply With Quote
Old 07-08-2010, 05:41 PM   #2
Islay - 63 O.
dufferin's Avatar
Montreal , -
Images: 11
Send a message via MSN to dufferin
do you plan to travel with your AS, or will it stay still... cause, not that it was my job, but I learned stucco, tadelak... and there is almost no way to make those finish last in a travel trailer.
Way too much vibrations while in motion the finish will fall apart.
Canadian Atlantic Unit Past President
Protect your dream from others and first yourself...
Few rolling wheels to make our planet a house.
A 1/5th of her that I own.
TAC# : QC-1
my blog
http://rvcampreview.com
dufferin is offline   Reply With Quote
Old 07-08-2010, 05:49 PM   #3
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
If your 're talking about masonary stucco, I wouldn't think it would work to well for a few reasons. First weight. 2nd it doesn't have a good adhesive property to stick to substrate, and 3rd too brittle resulting in cracks. You maybe thinking of more of a texture paint to achieve a rough surface, some times it might be called stucco, that might work.
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 07-08-2010, 06:40 PM   #4
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
I don't know - I'm thinking Clay AND Stucco . . . and maybe some wood trim around the windows . . .
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 07-08-2010, 07:04 PM   #5
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
There are synthetic replacements for both - dryvit is one they layer over foam board insulation on high rise buildings...
Old 07-08-2010, 08:56 PM   #6
2004 30' Classic Slideout
Albuqueruqe , New Mexico
Ummmm no… Straight from the land of enchantment NM where almost every house has a stucco finish…. It will not stick, and even if it did it would crack in a million pieces the first bump you took. Hell I can’t even get it to stay on my 50 year old house!
nmgt350h is offline   Reply With Quote
Old 07-08-2010, 09:48 PM   #7
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
ha ha! nmgt350h.... But he mentions wood trim around the windows...those old 'half round' cedar fence posts, make the most beautiful wood when stained. I have a wood box next to me that is made out of it. AND there is another slideshow on here somewhere - where the fellow did the whole interior of his with wood and did an amazing job too.
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Walls need help! WcfdPiper General Interior Topics 4 07-21-2009 10:18 PM
bathroom walls mrauch Upholstery, Blinds, Walls & Interior Finishes 1 11-19-2008 03:56 AM
'67 Caravel walls? modarch Upholstery, Blinds, Walls & Interior Finishes 5 06-14-2008 11:19 PM
Wood Walls donf General Interior Topics 2 05-31-2006 06:12 AM
getting behind the walls... Chuck General Interior Topics 14 07-11-2002 12:20 PM
