Old 11-11-2008, 08:13 PM   #1
1994 34' Limited
Troy , Ohio
Question Ceiling Liner in 94 Classic Limited 34
Bought it a couple months ago. 1994 Classic Limited 34'. When the cool November temps hit OHIO (around 30 degrees) the ceiling vinyl started to de-laminate and hang down.
Need some repair suggestions. The foam has some sort of grainy stuff on it which might making gluing hard. Can it be glued? What type of adhesive and technique to get this done? Dealer can replace it for about 1300 bucks. That's a little rich for me right now.
Emh142 is offline   Reply With Quote
Old 11-11-2008, 09:35 PM   #2
That delamination was a common problem, that was caused by the adhesive being water based.
Other than refastening it with screws and/or moldings, it cannot be repaired.
The old adhesive from the wall and foam, would have to be removed, which is impossible.
Adding new adhesive, to the old, will fail in a short period of time.
That's like putting new paint on top of bad paint that's crumbling. It simply will not work.
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 11-11-2008, 10:33 PM   #3
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
Check out the pictures of a "quilted" ceiling repair from the link in Rob's post here.
http://www.airforums.com/forums/show...7&postcount=57
I think I saw another "quilted" ceiling repair pictured here but couldn't find the post.
Here's a couple of threads to look over and there are more in the repair section forums.
http://www.airforums.com/forums/f39/...ing-40416.html
http://www.airforums.com/forums/f46/...lla-14989.html
Caroljb
I believe that if life gives you lemons, you should make lemonade... And try to find somebody whose life has given them vodka, and have a party.
photography
wheel interested is offline   Reply With Quote
1994, 94 classic, ceiling, limited
05 classic limited s.o. jack c Member Introductions 0 01-27-2007 07:28 PM
34 classic limited (1982) kayjos9497 Member Introductions 2 08-17-2006 11:19 AM
Classic? or Limited? or both?? maxandgeorgia 1993-1997 Limited 14 04-11-2004 06:02 PM
ceiling liner silverbullet96 General Interior Topics 13 11-28-2003 12:39 PM
86 classic limited 34 Ernie2007 Airstream Trailer Forums 1 04-29-2003 05:48 AM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
