Old 08-13-2010, 03:51 PM   #1
1988 34' Excella
Troy , Texas
Can you clean fuzzy walls?
We just purchased a 99 34' Excella Classic. There are dark spots on the wall fuzz that another Airstreamer identified as rivet dust. It appears that the PO tried to clean the walls and now there are stains as well as rivet dust. Has anyone had any success cleaning this wall fabric (I have heard it described as mouse fur)? At this point, I would be happy just to remove the stains left by the PO. I think I could handle the rivet dust. I am afraid to use any product on the walls. Has ANYone had ANY success with a cleaning product that makes it better instead of worse?
excella88 is offline   Reply With Quote
Old 08-18-2010, 07:00 AM   #2
ctalley316's Avatar
2006 25' Safari SS SE
Eden , North Carolina
I need to clean my walls as well. When our Airstream was new it had some leaks that the Airstream dealer repaired but... they didn't clean the walls.
Some of them have some mildew as well.
Please need advice.
ctalley316 is offline   Reply With Quote
Old 08-18-2010, 07:46 AM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
As a last ditch effort I hired a franchised carpet/wall covering cleaning company to work on my problem hull liner. The overall appearance brightened up....I had no odor problems, but I suppose if there were something there the process would have fixed that. The black spots...NOTHING, It did not touch them. It cost 60.00 and they came out to my location....no easy task.
Old 08-18-2010, 08:54 AM   #4
RangerJay's Avatar
2002 19' Bambi
Northwestern Ontario , - on the backside of the map and just above the big green spot
Images: 44
I can tell you what NOT to do .....
Before I got into Tim A's paint solution (see http://www.airforums.com/forums/f46/...tml#post671830) I thought I would try one more cleaning product (Oxygenics?) - and it seemed to improved the appearance of the fuzz - but not the backing - so - more is better - right??? ....
.... not right .... more was definitely not better - wet aluminum dust turns into a slurry - that runs - a lot ....
This took us way past any paint solution .....
We are now in replacement mode ....
The only good thing that came out of this??? ......
..... my wife forbids me to ever touch a cleaning product again .....
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2009 (The Buggy)
"I'm not young enough to know everything ....."
(Oscar Wilde)
RangerJay is offline   Reply With Quote
Old 08-18-2010, 12:23 PM   #5
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
I used a Dirt-Devil hand-held carpet cleaner on some spots on the walls. It works like the big carpet cleaners by spraying solution, rotating brush, and vacuum. It removed most stains quite nicely, but it did not touch the black stains where road dirt had leaked in at the base of the walls.
I had to spray the solution while holding the Dirt-Devil horizontal, but it worked just fine on the scrub and vacuum by following the contour of the wall.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Removing fuzzy felt/carpet on walls mattmichelle Upholstery, Blinds, Walls & Interior Finishes 4 09-24-2010 07:02 PM
How Do I Clean The Upholstered Walls? Chaplain Kent Upholstery, Blinds, Walls & Interior Finishes 5 05-20-2009 08:26 AM
Product(s) to clean interior walls? YOGINA 2002 - 2005 International 1 04-26-2009 01:05 PM
Painting fuzzy fabric walls dickschaak General Interior Topics 8 02-28-2009 05:25 PM
Cleaning Fuzzy Interior Walls?? Steve Heywood Upholstery, Blinds, Walls & Interior Finishes 21 09-19-2006 08:42 PM
