Old 07-30-2010, 08:59 PM   #1
2006 22' Safari
Eugene , Oregon
Rivet Black Spots on Interior Walls, Ceiling
2006 Safari
White fabric wall and ceiling covering is developing black spots in somewhat random locations. One area has several spots in a line as if associated with a rivet line. However, the spots do not align with the exterior. The other areas are not in any alignment. The trailer is stored outdoors but I keep dessicant for dehumidification inside.
I'm concern about leakage or mold from condensation from the aluminum under the fabric wall covering.
Any knowedge or recommendations would be apprciated in order to remedy the problem.
Thanks much, Billie Bob
Billie Bob is offline   Reply With Quote
Old 07-30-2010, 09:31 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Billie Bob -- welcome to the forums!
You've got the white fuzzy walls inside? These random spots are usually along interior skin seams. Fine aluminum dust is generated from road rattle & bumps. It works its way through the fuzzy wall coatings and shows up as dark spots.
A remedy ... ? Wish I had that at the tip of my tongue but I have bare metal interior and so haven't had to deal with this. Let's see what others say.
5 meter Langford Nahanni
Old 07-30-2010, 09:34 PM   #3
A quick google search on: "aluminum dust" site:Airstream Forums - Airstream Owners Community
Results:
Old 07-31-2010, 08:28 AM   #4
1960 24' Tradewind
Riverside , California
There's a product available called FOLEX that will remove just about anything from fabrics, combine that with a Wet/Dry vac and it may do the trick...Lowes, Home Depot both cary it.
Greg
1960 Tradewind
2007 Denali 6.2
2005 ST 1300 ABS
2005 Chevrolet SSR 6.0 LS2
airstreamlosangeles.com
ZoomZoom is offline   Reply With Quote
Old 07-31-2010, 09:33 AM   #5
_
zoomzoom...
while fol'x looks like a safe, low toxicity stain remover...
it appears to be for organic stains and not for disolving/transforming metal compounds ...
so it's doubtful it will have ANY effect on the black aluminum oxide/mixed metal dust stains.
airstream SHOULD be using a membrane/tape/barrier between the metal inner skin/rivets and mouse fur....
so that these aluminum/alloy/misc METAL oxide dust stains don't make it TO the WHITE mouse fur.
((or change to something BETTER than ozite))
the basic question is HOW to get mixed metal oxide dust staining OUT of a polypropylene fabric.
without damaging the glue, fabric or metal backing.
PREVENTION by better assembly techniques would SOLVE the issue.
lotz of old posts on this...
including LINKS to how the MAKERS of ozite recommend cleaning EACH type of stain...
http://www.airforums.com/forums/f39/...lls-22750.html
http://www.airforums.com/forums/f46/...lls-48767.html
cheers
2air'
Black Spots on Ceiling Fabric RangerJay Upholstery, Blinds, Walls & Interior Finishes 15 02-18-2015 07:52 PM
Covering uncleanable mouse fur walls and ceiling 3 Dog Nite Upholstery, Blinds, Walls & Interior Finishes 15 11-10-2010 12:13 PM
Black Spots during polishing? chazwars Cleaning, Stripping & Polishing 10 06-20-2008 08:49 AM
Painting Interior walls, Ceiling DJbyRequest General Interior Topics 37 05-29-2005 09:51 PM
Just started Compound Polishing. What are these black spots? TBKP's Overlander Cleaning, Stripping & Polishing 5 04-03-2003 12:34 PM
