Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Upholstery, Blinds, Walls & Interior Finishes
Old 02-05-2005, 11:02 AM   #1
Profile:
Bending New Aluminum Drapery Tracks
Hello, I am new to Airstreams, and this forum.
Greetings:
I just purchased aluminum tracks from the Airstream factory but do not know how to bend the tracks without putting a kink in it. The 6 ft. tracks are intended for the lower front from the street side all around to the curb side. Any advice from an experienced Aluminum bender would be appreciated.
Rob.
Chugalug is offline   Reply With Quote
Old 02-05-2005, 06:58 PM   #2
Profile:
All the curved tracks I have seen appear to be "factory bent", and rather long. I have some extras, and there are people who want them, but there is no economical way to ship them.
Mark
'85 Sovereign, 25'
Old 02-06-2005, 09:44 AM   #3
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
Find a rod that fits snug to slide up the track to keep it from collapsing. Grease it so you can pull it back out.
Don't try to bend it against a edge. The edge will be a fulcrum point. Find something round to work it over or do light bends with your hands a little bit at a time and move down a couple inches.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 02-06-2005, 08:07 PM   #4
Profile:  LOST , Hawaii
Find something big and round to roll it around, even a 5 gallon bucket will work.
John
74Argosy24MH is offline   Reply With Quote
Old 04-03-2005, 06:54 PM   #5
Profile:
Hi, Teardrop Trailer method
The way that I bent a 3/4"wide x 1/2"deep x 5' long 1/8"thick U channel was to make a form out of plywood, anchor one end of the material on the form. Put on a thick pair of leather gloves. Light a propane torch up and working the the metal slowly around the form until it stays in the shape that you want. Do not use a hammer. If you use this method it will destroy any coating or chemical process that the Alu has gone through. You could have it clear powder coated after you finish your forming process.
Jay Wheeler is offline   Reply With Quote
Aluminum Trim Source? melprice Cabinets, Counter Tops & Furnishings 6 09-08-2009 06:19 PM
463 inches Aluminum Curtain Tracks 4 Sale Cat Parts Archive 8 05-10-2004 12:56 PM
Sheet Aluminum repair lee_jachter Ribs, Skins & Rivets 8 11-23-2002 08:48 AM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 05:49 PM
Question re how to cut aluminum sheeting and get a clean edge... williamhenshall Ribs, Skins & Rivets 7 06-12-2002 05:58 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
