Old 07-29-2014, 08:35 PM   #1
1975 29' Ambassador
Fort Wayne , Indiana
Bedroom Walls - Paper Peeling
The wallpaper in our 1977 bedroom is peeling off. Can someone please send pictures or give me ideas on what to put on the walls once I have this contact type paper stripped off - Thanks so much in advance for any ideas
tweetie1966 is offline   Reply With Quote
Old 08-03-2014, 10:17 PM   #2
gYpsydreamin's Avatar
1975 31' Sovereign
Waldorf , Maryland
What are you using the strip the paper? Just curious because I'm thinking of doing the same.
gYpsydreamin is offline   Reply With Quote
Old 08-04-2014, 06:19 AM   #3
thehandyman's Avatar
1980 24' Caravelle
corpus christi , Texas
If it is the partition walls you can use a heat gun on low it will soften the glue enough on what is still stuck on. To much heat and the wall paper will tear just let it cool a few seconds and start again. Slow gentle pull and it will come off. keep the heat where the paper is pulling off the wall. Wipe down with mineral spirits let dry sand down any rough spots. The good primer and paint with your choice of colors.
thehandyman is offline   Reply With Quote
peeling interior walls 2manyhobbies Cabinets, Counter Tops & Furnishings 0 04-24-2012 07:14 PM
Peeling wall paper 1990 excella Sierra Skier Upholstery, Blinds, Walls & Interior Finishes 7 10-30-2011 10:31 AM
Peeling wall paper DEWASSINC General Interior Topics 1 07-24-2011 07:52 AM
Padded fabric on the walls (rear bedroom) Joe Z Upholstery, Blinds, Walls & Interior Finishes 5 03-08-2004 08:54 AM
Exterior paint peeling! Astrodokk Airstream Motorhome Forums 2 08-10-2003 08:18 PM
