Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Upholstery, Blinds, Walls & Interior Finishes
Old 12-23-2006, 09:42 AM   #1
Profile:  acton
bathroom wall material
I have to replace the wall that goes next to the tub and divides the bathroom and bunk area. Do they make a panel with one side waterproof? This is for 63 tradwind.
durans54 is offline   Reply With Quote
Old 12-23-2006, 02:59 PM   #2
Profile:  , Minnesota
Images: 59
Airstream Registry
I think you could go one of three ways on this.
1. Use a heavy vinyl to cover one side of the plywood. This is the way the original was done.
2. Coat the wet side with exterior Spar Urethane. Or even epoxy resin.
3. Buy a sheet of shower liner fiberglass panel. That's the white pebbly stuff you see at Home Depot. Problem with this is you will need to get wall channel that is thicker, or rabbet the plywood side so that both fit into the wall channel. The channel is less than 1/4".
Good luck with whatever you decide. I think the vinyl on mine is ok and I am going to leave it the way it was.
Old 12-23-2006, 03:49 PM   #3
Profile:  acton
You mentioned wall channel, do they make wider channel and who carries it?
Old 12-23-2006, 04:17 PM   #4
Images: 59
Airstream Registry
You can look, or you could do what Airstream did.
The wall between the bunks and the kitchen is a double thickness of plywood. They took two lengths of channel, split it on a saw, and made it fit the double thickness.
Or you could buy two pieces of angle aluminum and rivet them leg out, with whatever space you need in between.
I checked Brunner Enterprises but I didn't find anything that would work.
Old 12-23-2006, 06:52 PM   #5
Profile:  1960 24' Tradewind
santa barbara , California
On our 60 trdwnd ,the panel was fine but the old sticky type of covering on the shower side needed replaced ,it was like that shelf lining sticky vinyl stuff
looked original as in one big sheet .I bought some of that white pebbly bath
covering at home depot .I measured the curved section needed and cut it out with a jig saw with a fine blade .I did a test fit then proceeded to sand
the edges to get the contour right .I used sheet plastic adhesive ,also at home depot and used a trowel to apply it so you have an even thin coat of
adhesive .I did have to remove the old shower diverter /faucet (replaced it)
Lastley ,it does not fit into the aluminum channel ,I cauked the edges all
the way around to seal it .The covering fits nicely flush with the channel and looks great.Basically the same thing markdoane has said to try and it works.
Scott
scottanlily is offline   Reply With Quote
Old 01-22-2007, 08:41 PM   #6
samb's Avatar
Profile:  1961 22' Safari
Union , Oregon
Images: 11
There is one more option to consider. I just completed this method in my '61 Safari with great results. I used 1/8" plywood with FRP (fiberglass reinforced plastic---The pebbly stuff from Home Depot) attached to it with the panel adhesive. The end result is a 1/4" panel that is waterproof and fits well into the channel. The panel seems to be even stiffer than the original 1/4" panel. Just another thought to add to the confusion!
Sam
samb is offline   Reply With Quote
Old 01-22-2007, 09:54 PM   #7
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
Sam
I used that stuff also.
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
Defendwally.org
Old 01-23-2007, 06:05 AM   #8
muddy_hollow's Avatar
Profile:  1965 20' Globetrotter
1956 22' Caravanner
Mendon , Massachusetts
Send a message via AIM to muddy_hollow Send a message via Yahoo to muddy_hollow
Other options
Check out fx sheeting from Alsa Corp. www.alsacorp.com
Not cheap, but the product water proof, and looks great.
Doug
56' Caravanner 'The Broomstick'
muddy_hollow is offline   Reply With Quote
Crashed on a wall !!!!!! brunoffrance Exterior Restoration Forum 48 03-18-2008 02:21 PM
Poor design on slide bathroom door lbrodsky 2001 Safari 15 04-17-2005 08:01 AM
What kind of paint for a louver cover for a wall panel heater cindy General Interior Topics 1 09-19-2002 08:38 AM
What the heck is that switch on the wall??? TRAPEZE Airstream Motorhome Forums 7 09-10-2002 04:05 AM
Bathroom Counter Trim 74Sovereign Upholstery, Blinds, Walls & Interior Finishes 1 07-10-2002 06:36 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
