Old 01-22-2006, 10:25 PM   #1
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Bathroom trim
I have this plastic (?) trim in the bathroom of my 75 Trade Wind. It has become hard and discolored. It is 1 inch wide and is all over the bathroom. They also used it as trim under the cabinets in the very front of my unit. Can anyone point me to replacement material? I figure I will need around 40 feet of this stuff. I am not even sure what color this was originally.
ID:	17866   Click image for larger version
Richard
Old 01-23-2006, 03:39 AM   #2
PizzaChop's Avatar
1973 31' Sovereign
Danielsville , Georgia
Images: 202
Cheap Alternative (linoleum strips)
Unless you're locked into keeping it all original, strips of linoleum (available in 12' wide pieces at Lowe's/Home Depot) worked quite nicely for me and allowed me to match the floor and decor of the bath.
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Old 01-23-2006, 05:30 AM   #3
ssww's Avatar
1975 27' Overlander
Longview , Texas
Pizza,
What kind of paint did you use for your bathroom? My 75 AS bath looks exactly like your before pic. Well, the paint anyway and woever had her before me must have taken some panels out . There is caulk smeared around all of the seams and tub. And I mean smeared!!! Like 1-2 in. thick. Maybe they were trying to hold it together. Wo knows.
Scotty
  • 06 F-250 4x4
  • 80 FLH HD (restored)
  • 75 Overlander (27 ft.)
  • 1959 Ford 661 tractor (full restoration)
ssww is offline   Reply With Quote
Old 01-23-2006, 06:41 AM   #4
PizzaChop's Avatar
1973 31' Sovereign
Images: 202
We used 2-part epoxy (Tough as Tile), available at Lowe's for about $25.
Here's a pic of the Overlander paint, the Sovereign paint, and the finished bath.
It is brushable a well, but I prefer to spray it. (Cleanup is a bit messy.)
It can be done in place, if you remove all your trim and prep it thoroughly.
Ron Kaes
Psalm 112
www.paparonnis.com
Old 01-23-2006, 07:39 AM   #5
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
A very cheap but very nice alternative is to remove it and simply use the bronze which is underneath it. I did this with my 75 Tradewind and now with my Motor Home. (Although I am certain Balrgn has replaced it with the exact same plastic trim which was there from the factory in the '75 Tradewind. He probably has even found a way to fade it a little to give it a '75 look. He bought my 75.) I liked the metal trim better than the plastic. It looks classier and no one will ever know it once held a cheap looking plastic trim. (That is no one but Balrgn.)
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 01-23-2006, 07:54 AM   #6
myboyburt's Avatar
1993 25' Excella
Beautiful , New Hampshire
Images: 12
Balgrn redid his bath in his 75 Tradewind last year, not sure he has installed trim yet. I do believe he was planning to. For folks who haven't already done so check out his website, he did a fantastic job.
Michelle & Leon
New England Unit
myboyburt is offline   Reply With Quote
Old 01-23-2006, 09:53 AM   #7
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
I did put the trim insert in, Trimmed some verticle blind replacments from Home Depot. Worked perfect!
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 01-23-2006, 09:16 PM   #8
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
This material is called "nosing" and can be found at Inland RV in California. They sell it by the foot. I replaced about 9 feet of it in my Excella bathroom about 6 months ago. It is closer to the color of your headliner than the yellowish color you see now.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Aluminum Trim Source? melprice Cabinets, Counter Tops & Furnishings 6 09-08-2009 06:19 PM
Poor design on slide bathroom door lbrodsky 2001 Safari 15 04-17-2005 08:01 AM
blue trim molding larry smith Clearcoat, Exterior Paint & Trim 83 12-07-2003 11:04 AM
Bathroom Counter Trim 74Sovereign Upholstery, Blinds, Walls & Interior Finishes 1 07-10-2002 06:36 AM
Exterior trim ALANSD Airstream Motorhome Forums 1 04-14-2002 07:53 PM
