12-18-2008, 08:10 AM
Divide
Bathroom surface refinish question
I have been looking at a mid 70's Tradewind and although I like the trailer it's self the bathroom is that nasty 70's yellowish tint . Is there any way to change the color short of tearing it out and starting over. A full bathroom gut is not in my budget. I'm thinking maybe an epoxy based pait or something like that. What do you guys think?
12-18-2008, 08:17 AM
Corona
The plastic bathroom furniture can easily be refinished.
Proper technics and of course top of the line materials must be used.
Many commercial companies offer that service as well.
12-18-2008, 08:49 AM
Divide
What materials are used to do the refinish. I want to do all the work myself not only to save money but because I enjoy doing that sort of thing (not getting high on the fumes).
12-18-2008, 08:53 AM
1998 28' Excella
Dolores
First off, how is the weather in Divide, Co. We have been under a storm warning for past 3 days and overall have about 14" of the white stuff in our yard. With Divide being a little higher elevation than SW Colorado you may have more. Anyway, if you have a steady hand and are not afraid of a spray paint, their is a spray paint on the market that is especially designed for vinyl and I am sure it would work on the bathroom fixtures. We had some nasty green colored vinyl lawn chairs and used the spray paint on them and painted them to match the blue stripe on our Excella and that was 4-5 years ago and they still haven't lost their color.
Just an idea and may help you from "hiring a professional". Only thing you will need to worry about would be ventilation and overspray. It can be purchased at any of the big box stores. I think we paid about $3.97 per can.
Enjoy....
Member Four Corners Unit/CAC
WBCCI # 10105
AIR # 28748
12-18-2008, 08:58 AM
Austin
Hey GVD, there are many folks who have done this, and there is a lot of information on this Forum about it. I know that some have used the Krylon paint formulated specifically for plastics, I think it is called "Fusion." According to some who have used it, it seems to have held up well, at least for a season's worth. I don't know if anyone has much more data than that, though.
Others have used epoxy paints with great results too.
The first step is to figure out what your bathroom parts are made of, whether it's ABS plastic or fiberglass or something else, because that will determine the products that you use. I don't know much about the 70s models, but there are a LOT of people on here who do. I think it's some sort of ABS plastic.
For ABS plastic, several people have used and recommend Tough As Tile epoxy paint that can be found at hardware stores and the big boxes as well.
Here's a webpage for a forum member who redid his whole bathroom with 2-part epoxy paint-- he didn't mention the brand, but the results are great:
1972 27
Good luck!
12-18-2008, 09:03 AM
Loganville
, Georgia
I bought my epoxy white paint at lowes. It is called 2 part epoxy. I sanded with 000 steel wool, painted it on. Let it dry sanded again and then sprayed it on. It came out looking like porcelain. check out my link.
http://www.airforums.com/forums/f36/...n-38204-7.html
Also check the last page and you will see the bathroom put back together.
Lothlorian
Brian & Adrienne
12-18-2008, 09:35 AM
Divide
The weather up here is cold but we haven't gotten a whole lot of snow. Plenty of drifting from the last storm due to the wind though. Thanks for all the replies, this gives me hope that I'll be able to convince my wife it's better to get a 70's AS then a box trailer from the early 90's. I keep telling her that I can change the 70's color scheme and now I can tell her how, and it's even affordable if I do it.
12-18-2008, 09:50 AM
Loganville
, Georgia
My wife was not into a trailer at first until we bought retirement property. She never liked any of the trailers we looked at until I showed her the airstream. She has been the major player in decoration and colors. She really likes it and finds it to be more open and visually pleasing. Take your wife do a walk through of an old airstream. That may convincer her.
Lothlorian
Brian & Adrienne
12-18-2008, 11:21 AM
1979 30' Argosy
Havelock
, where we park it
Hello... The vinyl covering in our bathroom in the Argosy was lifting.. so we removed all of it and got white eraserboard in 4x8 sheet and cut it to fit and used contact cement and redid the walls to the bathroom in that... for the shower we used a pieced shower kit and did all of the walls in that... Hubby painted the shower pan and outside wall for the shower with brilliant white from Por .... We have been living in it since Nov 8 as we are snowbirds.. and the bathroom looks great...
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
12-18-2008, 11:49 AM
Corona
Your bath parts are ABS.
Follow the suggestions in post # 6.
It's best however, to use a primer after the sanding. Then sand the primer down so that you can obtain a smooth finish.
Epoxy paints are good, and so are automotive paints (not in spray cans), but bulk, where you would use a spray gun.
12-18-2008, 02:35 PM
Ottawa
, ON
Here's a link to a "Classic Ride" show where they do just what you are thinkg of doing to your trailer.
Click .
12-18-2008, 02:41 PM
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge
I like to use fiberglass "gelcoat" this is the last coat used in the constuction of boats, it comes in amy color you can think of and is the only thing I feel will last! (constant abuse and water) It is easy to use but the fumes are very strong!
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
12-18-2008, 04:08 PM
Divide
So if I do a gelcoat then my buddya and I will come out of the trailer looking like cheech and chong? That could be interesting. On a more serious note, how intensive is it to do a gelcoat to ALL the plastic surfaces (I'll just replace the the potty).
12-18-2008, 07:20 PM
1994 34' Excella
Mount Vernon
, Kentucky
Click .
While you are at it, Check out all the work they did on this airstream. They had a lot of neat ideas.
