Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Upholstery, Blinds, Walls & Interior Finishes
Old 06-28-2002, 09:50 AM   #1
Profile:
Question Bathroom Counter Trim
Hi Everyone!!
I am the proud new owner of a 1974 Sovereign!! For the most part- the interior is great but there's a problem with the track that goes along the (rear) bathroom counter where the shower door hooks up. It has come loose & was repaired with some kind of caulk which isn't holding so it buckles. Is there some kind of adhesive that's designed to do this job?
Also, the counter has some dark stains which look like rings from hairspray or shaving cream cans. I'd like to get them out but don't want to ruin the surface. Soft Scrub with Bleach, Oxyclean or Zud?
Thanks so much for your help!! I have already learned so much just from going thru all the other posts & it means a lot to me to have this great resource!!
74Sovereign is offline   Reply With Quote
Old 07-10-2002, 07:36 AM   #2
BobbyW's Avatar
Profile:  1965 20' Globetrotter
Houston , Texas
Have you tried Automotive rubbing compound. It comes in various strengths and grits. Use gentle pressure on a small area to test. Then wax with a good auto paste.
Also LimeAway can be used to remove mineral and rust stains. Just be sure to read the instructions first to see if it is safe for the materials you use it on.
-BobbyWright
-BobbyW AIR# 123
-Guess what? I got a fever! And the only prescription.. is more cowbell!
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."
-Red Green
www.bobbywright.com/gallery
BobbyW is offline   Reply With Quote
Poor design on slide bathroom door lbrodsky 2001 Safari 15 04-17-2005 09:01 AM
70's veneer and bathroom trim davidz71 Cabinets, Counter Tops & Furnishings 4 03-26-2004 08:58 AM
Vinyl/plastic Trim Around The Inside Of Windows Tim T Parts Archive 8 10-21-2003 04:02 PM
Pergo in the bathroom Chuck Floor Finishes 8 08-05-2003 06:13 PM
Door Trim smily Doors & Locks 1 01-03-2003 09:27 PM
