Old 02-20-2015, 05:23 PM   #1
1999 28' Excella
New Orleans , Louisiana
Bathroom bench wall carpet by the throne?
OK, what is under this box by the throne? Help..the carpet has to go and would love to eliminate the bench/box.
As you already know it is a 1999 Excella.
Thanks, Kat
badkat is offline   Reply With Quote
Old 02-20-2015, 08:07 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Might b the cover for water heater? Got pics?
Peace and Blessings..
Channing
WBCCI# 30676
Old 02-21-2015, 08:35 AM   #3
1999 28' Excella
Hot water tank is under the vanity. I think it cannot be elimated..think it is the wheel well..hehe!
Old 02-21-2015, 08:47 AM   #4
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
If I remember correctly, it is a little box built in order to raise the toilet up above the plumbing connections. There is nothing under it except the vertical pipe. You will notice that you have a low rise toilet. We replaced all the carpeting in our Safari with vinyl flooring. Way easier to keep clean. Jim
Jim Flower is offline   Reply With Quote
Old 02-21-2015, 11:09 AM   #5
Dallas Center , Iowa
I don't remember why the box but I did a modification that came out great in my former Excella. This was next to the toilet and not under it. After removing the carpet and cleaning it off I put matching oak veneer over the entire thing and trimmed. Looked factory done and was very happy with it.
Earthcreeper is offline   Reply With Quote
Old 02-22-2015, 10:14 AM   #6
MontyV's Avatar
1994 34' Limited
Salem , Oregon
So I am confused. I thought you were talking about the 5" shelf that protrudes from the cabinet. When I replaced the carpet I put in parquet flooring, and covered the shelf with the same. I used a piece of 90 degree molding to cover the edges and stained it to match. I am pretty sure this is a bump out for wheel wells but I didn't pull my cabinet apart to check. Some posters seem to think you are talking about a riser under the toilet, I don't have one of those so I can't help if that is what you are talking about.
MontyV is offline   Reply With Quote
Old 02-24-2015, 07:14 AM   #7
barefootmom's Avatar
1998 30' Excella 1000
Glendora , California
We are in the same boat. We tore out the carpet and are installing "copper slate" (vinyl) tile. I would love to ditch that protrusion and replace the toilet with one that has a narrower base to make cleaning easier (and provide more elbow room!). We've looked online for replacement toilets but can't find one (yet) whose hole pattern (at the base) matches existing. Any suggestions?
barefootmom is offline   Reply With Quote
Old 02-24-2015, 09:33 AM   #8
Livingston , Texas
I have the same rig as you, and replaced my original Thetford a few years ago. The new Thetford mounting bolts were aligned differently then the old. From a post on this forum, some where, I found that the floor flange can be unscrewed enough to get the toilet mounting holes to align most anywhere you need them. I did have to construct a "wrench" with a board and two bolts to get the flange to rotate. Search the forum. You can also adjust the flange height somewhat if you have changed the flooring height and need the toilet to seal on the foam ring.
Siegmann is offline   Reply With Quote
I have put a TV on the wall behind the bench seat and table I need to get the antenna Trident Land Yacht/Legacy Motorhomes 34 09-07-2015 08:47 AM
Carpet on Wall 2009 Julie-Bob Upholstery, Blinds, Walls & Interior Finishes 3 06-04-2014 02:57 PM
Going twice. Free to a good home, one like new RV throne polarlyse General Repair Forum 0 08-01-2013 08:57 AM
The Throne and The 23FB murreywalker 2009-2015 Flying Cloud 27 04-01-2012 01:07 PM
Wall-to-wall carpet alternative mcneon Upholstery, Blinds, Walls & Interior Finishes 9 11-20-2008 01:41 PM
