Old 07-21-2009, 08:21 PM   #1
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
Bathroom ABS repair-Reality check
Ok here's what I am thinking. I can repair the 6" x 7" hole in the plastic wall near the toilet(I'm guessing that it is ABS) by getting a larger piece than the hole to be patched putting it through the hole and gluing it from the inside. Then cutting another piece matching hole and gluing to backer piece. Then filling the gaps with something, sanding, smooth then epoxy paint the whole mess. The hole can be seen in the upper portion of the picture. I'm open and welcome suggestions as to glues, materials and process. Here's a link to the material I was thinking of using.McMaster-Carr
Mike
PS The floor repair is not my doing and I expect to rerepair!
SilverHoot is offline   Reply With Quote
Old 07-21-2009, 10:02 PM   #2
1973 31' Sovereign
Amherst , New York
You may be able to find some sheets of Styrene in various thicknesses from a local model or hobby shop that carries a variety of plastic model kits. The sheets will be a little cheaper, and you can avoid the shipping.
Also, for filling the gaps in styrene, I have used automotive finishing putty with success, although you may find a similar product at the model shop if it serves a "scratch build" crowd. It dries hard, is sandable & paintable, and won't shrink.
expat5 is offline   Reply With Quote
Pesky cracks in bathroom ABS counter Lumatic Cabinets, Counter Tops & Furnishings 14 07-19-2009 09:24 PM
POR15 reality check truckasaurus Repairing/Replacing Floor &/or Frame 20 06-07-2009 08:19 AM
My 1975 Argosy 20' MH bathroom--ABS or fiberglass?? kdenault Argosy Motorhomes 2 04-19-2009 02:55 PM
My 1975 Argosy 20' MH bathroom--ABS or fiberglass?? kdenault General Interior Topics 0 04-17-2009 11:24 AM
