Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Upholstery, Blinds, Walls & Interior Finishes
Old 09-21-2009, 04:31 PM   #1
the zenman
zenman's Avatar
Profile:  1972 31' Sovereign
wakefield , Quebec
Lightbulb Back of interior wall panels
This is my first post. I have searched this particular topic and could not find any info.
I have a 1972 Sovereign. I have removed the interior wall panels. I was playing around with attempting to strip a panel when I noticed the back of the panels, covered in a white paint, striped with one wipe when I was wiping away the excess stripper. This led me to look into using the reverse side of the panels stripped. Really easy to strip and prepped for polishing.
Now before anyone gets too upset I recognize the flipping of panels from left to right, and the rivet holes would not line up...have to do some cutting...but...the finished design of my trailer will actually leave me with panel material to spare as I am moving the rear inside wall forward 6 ft. including the overhead and recovering the rear section with new material. Has anyone tried this. Does it make sense or am I nuts? If you have a look at my website what I am attempting to do is explained under "zenmans mobile"
Thanks in advance for any comments.
Gerry...the zenman
Home
zenman is offline   Reply With Quote
Old 09-21-2009, 06:12 PM   #2
Kevin245's Avatar
Profile:  1976 31' Sovereign
Rock Hill , South Carolina
In theory I guess it would work, though there may be some issues with window opening alignment. If you're willing to live with the possibility of some mis-matched holes, it say give it shot.
Great line of thinking on your part. Let us know how it works out for you.
Regards,
Kevin
Experience isn't always the best way to learn...You usually get the lesson first...And the instruction afterwards...
Old 09-21-2009, 07:12 PM   #3
airstreamjudy's Avatar
Profile:  1968 24' Tradewind
Largo , Florida
What a cool office that will be for you. I would try your idea.
JudyW
airstreamjudy is offline   Reply With Quote
Old 09-22-2009, 03:14 PM   #4
the zenman
zenman's Avatar
wakefield , Quebec
Rivet Follow up on stripping wall panels and stripping windows
Hi all
Today I stripped a piece of wall panel about 3'X5'. It took me less than 5 minutes. I wanted to use XYLENE but had to settle for acetone. Used a stiff brush and then a rag. In my opinion the piece is now ready for installation and then a final touch up before polishing. Of course if anyone does this they must follow the safety instructions.
I also scraped the inside film off two windows...took about 30 min. for both. All in all I am quite pleased.
Swapping the wall panels and cutting will consume a bit of time but I am quite encouraged.
z
Name:	wall panel before.jpg
ID:	87573   Click image for larger version
Name:	wall panel after 5 min.jpg
Name:	window before.jpg
ID:	87575   Click image for larger version
Name:	vista before.jpg
ID:	87577   Click image for larger version
Name:	window in progress.jpg
Old 09-22-2009, 03:18 PM   #5
mello mike's Avatar
Phoenix , Arizona
Images: 14
Do you strip your windows with the same stuff you used on your panels?
Sterling - 1972 Sovereign Intl (RB)
Eddie - 2003 Ford Excursion (6.0L PSD)
Prodigy Brake Controller / Equal-i-zer Hitch / Honda EU2000i x2
Airstream Life Contributor
WBCCI 4CU #5661/AIR #5661
My Refurb Blog: UPDATED!!
http://mellomikesairstreams.blogspot.com/
Part wanted: 70s Kitchen Counter Unit
mello mike is offline   Reply With Quote
Old 09-22-2009, 03:59 PM   #6
the zenman
zenman's Avatar
wakefield , Quebec
glass stripping
No...I simply used a blade like you would use to scrape paint. On the thermals I removed the inside plastic pane first.
z
Installing stainless steel wall panels mcneon Cabinets, Counter Tops & Furnishings 25 04-13-2007 05:48 PM
Peeling wall panels wacnstac Cabinets, Counter Tops & Furnishings 3 11-30-2006 09:11 PM
Thickness of interior panels? crgintx Ribs, Skins & Rivets 4 10-17-2004 08:06 PM
Interior Panels happier General Interior Topics 16 10-07-2004 08:29 PM
Trim around interior panels Happycampers General Interior Topics 2 09-21-2004 11:38 PM
