Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Upholstery, Blinds, Walls & Interior Finishes
Old 08-11-2005, 10:05 AM   #1
Profile:  1978 25' Tradewind
Roseland , Florida
Awful sliding doors
Hi,
I am about done with renovations to my '78 Tradewind. One of the last things I need to do is get those sliding doors under the sink made operable. They are made by gluing long thin sections of pressboard to a canvas backing. The result is, (or was in 1978), a flexible sliding door. In my case the ease of operation has ceased and one had to be removed entirely, the other can be muscled open and shut. I will be trying to clean out the channel and apply silicone this afternoon, but could use any expertise in this area.
thanks,
Eric
Eric, Tina and Kierstin Hedin
'78 Tradewind - Homeschooling RV Tech
kooblekidz is offline   Reply With Quote
Old 08-11-2005, 10:54 AM   #2
moderator
Janet's Avatar
Profile:  Eastern , Washington
Images: 63
Hi - When those doors work - they're wonderful and save a lot of space. When they're broken - life is BAAAD. Use the search tool and search "tambour doors" Lots of folks have replaced or repaired them successfully.
77 Argosy Minuet, 6 metre | 77 Argosy 24, Rear door
AIR # 3181 | WBCCI # 5575
Bullies thrive where leadership fails
Janet is offline   Reply With Quote
Old 08-11-2005, 11:43 AM   #3
77 R GO C MH's Avatar
Profile:
If the doors are all intact, you'll probably find that thorough cleaning of the track and silicone on the track and tambor edge will help a bunch.
77 R GO C MH is offline   Reply With Quote
Old 08-11-2005, 08:24 PM   #4
Roseland , Florida
Thanks for the encouragement. I drilledout a rivet, cleaned out the tracks, glued down some of the tambour stuff and siliconed everything and they work fine. One of the tambours had come out of the track, getting it back in was quite the challenge, lots of cursing!
Old 08-11-2005, 08:35 PM   #5
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
Originally Posted by kooblekidz
Thanks for the encouragement. getting it back in was quite the challenge, lots of cursing!
Yes, working on a vintage Airstream is educational, you learn lots of new words you didn't think you would ever use!
Just an FYI, the later '70's tambours were a lot better than the early stuff. If you gave it a hard look, it would self-destruct.
(No Longer at Inland RV)
Old 10-21-2005, 10:44 PM   #6
Profile:  1977 31' Sovereign
Lake Oswego , Oregon
Wink Not a tambour fan...
I know it seems like the tambour was a great idea but it really is not so wonderful. The best part about the tambour is that it is not subject to opening while under way. That is their only real benefit. They take up much more room than a standard door as the roll receptical takes up storage space, not to mention weighing a lot. I removed all of the overhead compartments and all of the tambour doors in all of my cabinets. In all, I removed over 1000 lbs of material. (that is unless the dump is cheating me)
The truth is, the plastics, vinyl and heavy particle board construction of the Airstream interiors are not nearly as weight concious as many posts would lead one to believe.
I have lost some overhead storage but by removing the false walls used to accomodate the awful accordian doors, I have gained storage space lower in the trailer.
I can already hear the moans from those who consider tossing the 70's interior into the trash as major league crime....
topazken is offline   Reply With Quote
Old 11-05-2007, 08:58 PM   #7
Profile:  1978 31' Sovereign
tucson , Arizona
tambour doors
hi you have pictures of interior renovations on your airstream?
thx
desertrat1 is offline   Reply With Quote
Sliding Cabinet Hardware LKappenman Cabinets, Counter Tops & Furnishings 5 10-20-2002 05:53 PM
compartment doors Dave Cole Exterior Storage Compartments & Access Doors 2 10-08-2002 06:32 AM
Cabinet Door Retrofit to Tambour Doors ARGOSY79 Cabinets, Counter Tops & Furnishings 5 08-28-2002 09:34 AM
Roll up doors [tampor] ? niftypkg Cabinets, Counter Tops & Furnishings 5 05-17-2002 08:23 PM
Cabinet roll up doors niftypkg Cabinets, Counter Tops & Furnishings 2 05-10-2002 08:22 PM
