Old 02-20-2009, 02:22 PM   #1
TPdrums's Avatar
1972 27' Overlander
Mo Hill , California
Any Ideas for removal....
I just removed the fiberglass end cap in the rear of my Overlander. I'd like to get it out of the trailer to do some epoxy and fiberglass work on it. But, I can't seem to figure out how to get it out of the trailer. Can anyone offer some suggestions?
Todd
Fine Woodworking, Furniture, Carpentry, Drums, and Lutherie
www.ToddCreatedWood.com
http://toddcreatedwood.blogspot.com/
TPdrums is offline   Reply With Quote
Old 02-20-2009, 02:34 PM   #2
on the hunt
osolow's Avatar
riverton , Kansas
Send a message via Skype™ to osolow
it took two people but i got mine out by snakeing it out the door.
it will flex a little bit but dont push it to much or you'll have a lot of epoxying to do
personally i would look in to doing something else with the end cap.
if i would have had a little extra money when i removed mine i would have put up some sheet aluminum or somthing else that would look a little nicer and last a bit longer then the cheap thin plastic they used for the end cap.
osolow is offline   Reply With Quote
Old 02-20-2009, 02:56 PM   #3
DanB's Avatar
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain , Ohio
I've been told whatever is in the trailer came throught the door! If the construction practices used today were always used, this holds true!
DanB
________________________________
Proud Member of the Wally Byam Airstream Club #24260
www.campnova.com
The ďOhio Airstreamer -- Informal forum for weekend campingĒ thread.
DanB is offline   Reply With Quote
Old 02-20-2009, 03:39 PM   #4
VIKING's Avatar
Boulder Creek , California
I just pulled my front cap out. I put a corner out the door first and walked right out with it. The rear cap on mine is a little wider and it may need to be flexed a bit, but it WILL go. 2 people would be easier.
VIKING is offline   Reply With Quote
Old 02-20-2009, 05:33 PM   #5
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I trust every thing else is out of the trailer as in gutted
Old 02-21-2009, 12:36 AM   #6
TPdrums's Avatar
1972 27' Overlander
Yeah, everything is out of the trailer. And, I've had my father's help to try and remove the end cap. But, the more I twist it and roll it and try to get it out, the more damage it encures. i don't want to get it out and then have it reinforced so much that it wont go back in.
I think I may have to do the work to it while it is in the trailer.
I even measured the door and the cap, it seems like the cap its much to big to fit through the door. I have followed the directions in the manual for removal, but it just isn't working for me. And, I'd like to replace it with metal, but the cost is too much. So back in it goes.
Any ideas as to what this is ? Rollerboy Vintage Kin 11 02-01-2009 01:01 PM
Need ideas for BR remodel danalee General Interior Topics 2 01-04-2009 11:05 AM
Cabinet Removal - Closet Removal 2333 Cabinets, Counter Tops & Furnishings 2 10-05-2006 01:00 PM
A/C Won't Start - Any Ideas? myboyburt Furnaces, Heaters, Fireplaces & Air Conditioning 3 07-30-2006 06:13 PM
RV Ideas to consider ??? FrankR General Repair Forum 18 09-18-2002 10:43 PM
