Old 02-01-2011, 05:59 PM   #1
1971 27' Overlander
Scottsdale , Arizona
Aluminum Trim for Plywood Walls
Hi everyone, I'm redoing all the walls in my 71 Sovereign and can't seem to find this part anywhere. I'm looking for the aluminum C-channel trim that goes over the 1/4" plywood, side that faces the hallway. I only have the one for the shower wall to use as reference, it has ridges in them, they are so hard to find. I contacted InlandRV and they don't have anything either. Please help!!!
Motochi is offline   Reply With Quote
Old 02-03-2011, 01:51 PM   #2
MINTAIGE Missoula, MT
1961 24' Tradewind
missoula , Montana
I get my trim custom made at the local sheet metal shop, it took a little while working with the guys at Montana Metalworks but they've got it down now. all i need to do is a quick polish to remove scratches and cut it to length. Explain what you want to your local sheet metal and they should be able to come up with something nice.
mintageAIR is offline   Reply With Quote
Old 02-03-2011, 01:57 PM   #3
Whitefawn
whitefawn's Avatar
1978 Argosy 24
Scottsville , Virginia
Check the OUTWATER catalog- I got that name from the forum here and sent for a catalog and they have a mind-boggling selection of trims and "architectural products" made from metals and plastics. They have a website too-- outwater.com
Good Luck- we partially renovated our 1971 Overlander and finally changed gears, sold it and are re-doing a 1977 Argosy.
Kathy
whitefawn is offline   Reply With Quote
Old 02-03-2011, 02:24 PM   #4
cojer's Avatar
1966 17' Caravel
salida , Colorado
don't know if they would have what you're looking for but you might check out interstate metal fabricators
cojer is offline   Reply With Quote
Old 02-03-2011, 02:33 PM   #5
NicheVintage's Avatar
1965 26' Overlander
The Gorgeous Pac Northwest , Washington
Images: 34
We found something similar at Ikea of all places. It is aluminum and used as a channel to hold in their fastbo backsplash panels.
Since your in Scottsdale it's local too.
If I remember correctly it wasn't too costly and I think the channel is for 1/4".
Good luck.
WBCCI# 2578
Four Corners Unit
Our travel and resto blog:
http://web.me.com/tiffanydanley
NicheVintage is offline   Reply With Quote
Old 02-03-2011, 02:41 PM   #6
1965 26' Overlander
Images: 34
Here are a couple of shots. Might give you an idea of what it looks like before making the drive. Sorry for the quality I had to use my phone's camera.
ID:	121298   Click image for larger version
WBCCI# 2578
Four Corners Unit
Old 02-05-2011, 10:04 PM   #7
CampUnger's Avatar
Wabash , Indiana
1968 Airstream Glass Trim
Is this similar to what you are after? Possibly use it for the walls instead of windows? You could try to search for a similar item maybe, longer length etc...interested to know what you find!
Crystal
CampUnger is offline   Reply With Quote
Old 02-06-2011, 09:33 AM   #8
cojer's Avatar
1966 17' Caravel
salida , Colorado
found another website...a company called hoskin & muir that might have what you're after
Polished Aluminum Tanks NicheVintage Cleaning, Stripping & Polishing 12 07-05-2014 03:31 PM
Stripping Walls Advice (while on or off) vhariable Upholstery, Blinds, Walls & Interior Finishes 16 04-15-2011 11:23 AM
Aluminum Water Hose Al - K4GLU Fresh Water Systems 14 02-05-2011 05:47 AM
interior trim around door removal? Bill M. General Interior Topics 2 01-24-2011 08:25 AM
