Old 07-01-2010, 10:58 AM   #1
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
Aluminum over aluminum wall covering?
I've read numerous posts about painting the interior vinyl covered walls and I'm left not feeling really good about it. Peeling, cracking at the seams, flaking, etc.
So...I am wondering if anyone has installed new aluminum sheets over existing panels? If so, how is it holding up and do you have photos?
adwriter73 is offline   Reply With Quote
Old 07-02-2010, 10:22 AM   #2
Cantrell's Avatar
1988 34' Limited
1960 24' Tradewind
Mt. Pleasant , South Carolina
I guess no one has done it.
Some problems would be: lots of unecessary weight added and in drilling holes for new rivets means you are bound to catch a wire somehow, somewhere. Cutting and fitting new panels without removing the cabinetry and such would be a nightmare. Dealing with the rounded end caps would be no treat either.
We painted the inside of our trailer about 3 years ago and have had zero problems.
Bill Cantrell
AIR 24338
TAC SC-1
__________________________________________________
Easily distracted by shiny objects.
Cantrell is offline   Reply With Quote
Old 07-02-2010, 12:31 PM   #3
I've done it.
I installed aluminum panels over the fiberglass endcap in the rear bathroom, as well as in the center twin bedroom.
It added a little weight, but not too much really. And all of the other modifications I've done have reduced weight dramatically.
Catching a wire with your drill bit is certainly a potential hazard, but I did my best to determine where the wires might be, and avoid them. I didn't have any problems.
Here are some pictures.
Old 07-02-2010, 12:49 PM   #4
Journalist's Avatar
1969 25' Tradewind
Irmo , South Carolina
I haven't done it yet, but I'm planning to install an aluminum backsplash around my stove to make cleanup a little easier. The idea of cleaning splattered grease off of wood and vinyl doesn't seem like much fun.
AIR #8891
Unrestored 1969 25' Tradewind
Overkill Tow Vehicle of the Year Award:
2001 GMC 3500 4x4 Dually 6.6L Duramax
Journalist is offline   Reply With Quote
Old 07-03-2010, 08:18 AM   #5
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
Now we're talking! That looks beautiful.
Old 07-03-2010, 08:46 AM   #6
JSTOTT's Avatar
1965 26' Overlander
Chapin , South Carolina
Aluminum
I did an aluminum backsplash behind where the stove is going to go. I removed some of the original rivets and followed the line of rivets already there to cut down on the chances of hitting a wire. Since I rewired this trailer I had a good idea where the wires were to avoid them.
I painted the vinyl. It was not first choice but really the only option. We used a good adhesive primer and good paint so I'm hoping it holds up. If I had the choice ($$$) I would have gone all aluminum. I would probably pull out the cabinets to redo. Good luck.
Russ
JSTOTT is offline   Reply With Quote
Old 07-03-2010, 09:16 AM   #7
Jezibels's Avatar
1966 24' Tradewind
Chicago , Illinois
Utee94~
That is just plain awesome! Great job! I just may do this too, I need to take rivet 101 class 1st!
Happy Trails!
Jezibels is offline   Reply With Quote
Old 07-03-2010, 10:47 AM   #8
Journalist's Avatar
1969 25' Tradewind
JSTOTT, that's just exactly what I have planned. Very nice job!
AIR #8891
What's Behind this Fabric Wall Covering? Chasmorgan 1999 Safari 34 05-08-2016 11:20 AM
What thickness aluminum for interior wall coverage is good? and where 2 buy it? LAWFISH Interior Restoration Forum 10 03-07-2014 02:28 AM
Brrrrr... cold aluminum wall! longdog 2007 Safari SE 5 05-07-2009 05:56 AM
White fuzzy wall covering grantb4 Upholstery, Blinds, Walls & Interior Finishes 3 08-16-2007 08:38 AM
Delaminated wall covering? balrgn Upholstery, Blinds, Walls & Interior Finishes 15 02-20-2006 12:09 PM
