Old 02-11-2017, 05:43 PM   #1
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
Aluminum endcap
Today I finally started on my front endcap. This is 6 1/2 hrs!, only 12 more pieces to go!Click image for larger version
Cochese is offline   Reply With Quote
Old 02-12-2017, 04:49 AM   #2
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
Looks good, I used the same technique with wood door skins. The wood parts ended up needing steaming to make those compound bends. I too like the look better than the end caps.
sgschwend is offline   Reply With Quote
Old 02-12-2017, 05:51 AM   #3
Registered User
DDickey's Avatar
1957 22' Custom
Lago Vista , Texas
Nice!
What material are you using?
DDickey is offline   Reply With Quote
Old 02-12-2017, 07:19 AM   #4
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
I'm using 5052 .032 aluminum
Old 02-26-2017, 04:15 PM   #5
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
Getting closer... Olympics shaved, one more piece to go!Click image for larger version
Old 06-29-2017, 08:08 AM   #6
Bexar's Avatar
1960 24' Tradewind
San Diego , California
Aluminum endcap
About to embark on this project on my '60 24' Tradewind following your very helpful ideas. I know wood but not metal and it's not clear to me how to cut the aluminum sheet properly w/o damaging its edges. Eastwood makes an electric tool which seems to fit the need for cutting a clean line.
http://www.eastwood.com/electric-met...h6cRoCmiXw_wcB
What is typical for a project like this? You
Bexar is offline   Reply With Quote
Old 06-29-2017, 09:45 AM   #7
Registered User
DDickey's Avatar
1957 22' Custom
Lago Vista , Texas
The Eastwood nippers
will do the trick, I use some just like them and they make great, clean cuts
Old 06-30-2017, 04:53 PM   #8
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
I had mine sheared at a Sheetmetal shop
Old 07-01-2017, 06:55 AM   #9
Registered User
DDickey's Avatar
1957 22' Custom
Lago Vista , Texas
I should note though
that I sanded the edges with a table sander after I cut them with sheers. It worked beautifully
Old 08-03-2017, 06:30 AM   #10
Bexar's Avatar
1960 24' Tradewind
Could you mix 5052 & 20-24 T3 and have the same ease of installation and finished look?
Old 08-03-2017, 07:16 AM   #11
Registered User
DDickey's Avatar
1957 22' Custom
Lago Vista , Texas
I wouldn't
I wouldn't mix 5052 and 2024, the finishes will look different: the 2024 will be much shinier
Old 08-03-2017, 07:24 AM   #12
Bexar's Avatar
1960 24' Tradewind
Aluminum endcap
Thanks. That is good to know. I've stripped the factory Zolaton off the interior aluminum and will not repaint it. Am I correct the existing interior skin is 20-24 T3 or equivalent on this 60 Tradewind?
Old 08-03-2017, 09:44 AM   #13
1969 31' Sovereign
1982 28' Airstream 280
Edmonton , Alberta
Looks good!
-Assuming 20hrs for the project?
-You mentioned you had cut at a shop? On your end seam cut cuts would have a very slight concave due to the compound curve? Are the cut straight? Is the line perfect or are there minor "steps"?
- also for around your window did you just cut with hand shears ?
Swillv8 is offline   Reply With Quote
Old 08-03-2017, 12:31 PM   #14
Registered User
DDickey's Avatar
1957 22' Custom
Lago Vista , Texas
End Cap Material
It's 2024
Old 08-03-2017, 09:20 PM   #15
Bexar's Avatar
1960 24' Tradewind
Aluminum endcap
Originally Posted by Swillv8 View Post
Looks good!
Don't know what to expect time wise. Whatever it takes. This is a labor of love. I will not have a shop cut metal for me again. They used hand shears. Just used the right ones and made the cuts slowly and carefully. I was expecting them to use large metal shop tools for the cuts. If you refer to the very beginning of this long thread there is a discussion about the lack of need for cutting compound curves. All 11 panels are simple rectangles. And the only edges which will show is the center panels. Yes, just hand shears for cutting around the window.
Old 08-06-2017, 08:43 AM   #16
Registered User
DDickey's Avatar
1957 22' Custom
Lago Vista , Texas
Shears
These Harbor Freight electric shears make great, clean cuts. I used them to cut my end cap, then I used a table sander to sand the visible edge. Sanding wasn't totally necessary, but it did make the edge a little nicer
Best EndCap Paint & Shower Coating? Sav'h Steve Upholstery, Blinds, Walls & Interior Finishes 1 01-23-2011 03:54 PM
Um, where's my endcap aluminum? (57 SOTR) asta2 Ribs, Skins & Rivets 33 12-01-2006 12:02 PM
Swapping Interiors? Endcap Questions... sladew General Interior Topics 0 08-27-2005 01:58 PM
'61 Sarfari - plastic or masonite endcap? Rick Dotson 1960 - 1965 Safari 28 05-14-2005 07:24 AM
Cracked Interior Endcap LuminumTraila General Interior Topics 9 03-03-2005 07:23 PM
