Old 08-03-2017, 09:20 PM   #15
Bexar's Avatar
1960 24' Tradewind
San Clemente , California
Aluminum endcap
Originally Posted by Swillv8 View Post
Looks good!
-Assuming 20hrs for the project?
-You mentioned you had cut at a shop? On your end seam cut cuts would have a very slight concave due to the compound curve? Are the cut straight? Is the line perfect or are there minor "steps"?
- also for around your window did you just cut with hand shears ?
Don't know what to expect time wise. Whatever it takes. This is a labor of love. I will not have a shop cut metal for me again. They used hand shears. Just used the right ones and made the cuts slowly and carefully. I was expecting them to use large metal shop tools for the cuts. If you refer to the very beginning of this long thread there is a discussion about the lack of need for cutting compound curves. All 11 panels are simple rectangles. And the only edges which will show is the center panels. Yes, just hand shears for cutting around the window.
Bexar is offline   Reply With Quote
Old 08-06-2017, 08:43 AM   #16
DDickey's Avatar
1957 22' Custom
Lago Vista , Texas
Shears
These Harbor Freight electric shears make great, clean cuts. I used them to cut my end cap, then I used a table sander to sand the visible edge. Sanding wasn't totally necessary, but it did make the edge a little nicer
DDickey
1957 Custom
Link to my renovation: http://www.airforums.com/forums/f44/...cy-150509.html
DDickey is offline   Reply With Quote
Best EndCap Paint & Shower Coating? Sav'h Steve Upholstery, Blinds, Walls & Interior Finishes 1 01-23-2011 03:54 PM
Um, where's my endcap aluminum? (57 SOTR) asta2 Ribs, Skins & Rivets 33 12-01-2006 12:02 PM
Swapping Interiors? Endcap Questions... sladew General Interior Topics 0 08-27-2005 01:58 PM
'61 Sarfari - plastic or masonite endcap? Rick Dotson 1961 Safari 28 05-14-2005 07:24 AM
Cracked Interior Endcap LuminumTraila General Interior Topics 9 03-03-2005 07:23 PM
