Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Upholstery, Blinds, Walls & Interior Finishes
Old 09-20-2009, 11:40 PM   #1
Don Landis's Avatar
Profile:  Monterey , California
ABS/Epoxy Kits to Repair Moldings
While I wait for the coffers to refill, I've finally begun tearing out the interior to fix it, paint it, and slap the panels back up. Over at the Argosy MH forum section, I've attached some pictures of what I've started to redo. I'm not interested in taking it down to the studs, but I am interested in restoring and painting those bits that can be seen. There are various molded plastic panels up front -- including the big front interior end cap, which I just took off. I plan to fix all this trim with epoxy, then sand, repaint, and then reinstall with rivets. As I've read here, I ordered Marine Clean to degrease and clean up the ABS plastic.
But what is the best patch kit for ABS plastic/epoxy moldings? I've patched surfboard, so I know the program, but that's with resin. From what I understand here, epoxy is different to work with. I also need something like fiberglass cloth to put on those areas in the back that are cracked to strength it. Then it needs to be sandable. Any suggestions?
Second, what is the best paint for the ABS plastic/epoxy molding pieces? I've heard Krylon. But is there something better out there? Also, something more "green" so I don't off gas my little boys to death? What this paint work equally as well on the vinyl covered aluminum sheathing covering the walls?
Finally, I would like to replace some of the vinyl covered aluminum sheathing that covers the wall. But what with? I've been told 1/8" veneer doorsking plywood. Anyone else have any ideas? White plastic sheets? Lexan?
don
Don Landis is offline   Reply With Quote
Old 09-21-2009, 05:13 AM   #2
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
I use the Mas system, lookup JamesTown dist in RI.
Call and ask they are very helpful on boat issues
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
Old 09-21-2009, 06:18 AM   #3
Profile:  1968 24' Tradewind
Oxford, , Mississippi
I used West System epoxy and fiberglass cloth to do extensive repairs to plastic bathroom parts in my Trade Wind. Available from boat stores and Aircraft Spruce. If you use it spend the money on the pump kit. They screw into the resin can and hardener can and give the correct mixture with no measuring or weighing. Equal number of pumps from each depending on the amount of resin you need and the mixture will be correct. Saves tons of time.
Old 09-21-2009, 06:26 AM   #4
Silver Mist
LI Pets's Avatar
West is great also, but more expensive harder to mix the Mas system is fool proof 2:1.
They really do the same job.
WBCCI
Old 09-21-2009, 11:52 PM   #5
Don Landis's Avatar
I saw the West System in our local Marine Store - I live in Monterey - you can spit around here and find a marine store. But I just looked up the Mas System on the internet and all I found was an arcade dealer. Can you give me more specifics on the Mas system? Also, a good cheap internet site to buy it from? I assume the West System can be had cheaper on the net as well.
don
Old 09-22-2009, 12:26 AM   #6
Silver Mist
LI Pets's Avatar
.JamestownDistributors.com
WBCCI
Old 09-22-2009, 12:40 AM   #7
Don Landis's Avatar
Yes, I just found that great site. Ok here are the questions. The West system has a sporty kit with everything I need and an instructional video besides. But never once did it mention that I could use it with ABS plastic pieces. It sounded like it was more for fiberglass applications, which I understand I don't want with ABS plastic, which won't hold well with the vibration when traveling.
Whereas, the Mas System was definitely cheaper, but didn't come in a sporty kit and instructional video. What it did say is that it works with everything, but mainly as an adhesive. And it had a very low VOC, which is what I'm looking for with two little boys traveling inside my plastic/metal beast.
Does both the West and the Mas systems apply to ABS plastic?
What sands up better? What do I use to sand it?
don
Old 09-22-2009, 07:35 AM   #8
Silver Mist
LI Pets's Avatar
I've been using fiberglass over ....well a lot of years.
I've used both of these brands, to me the results are the same.
As far as instructional video go online and find them including instructions.
They both should adhere to the plastic sand the plastic first!!!!!
As far as sanding the finished job use what ever grit you like, just as you would with wood etc.
WBCCI
Old 09-23-2009, 12:25 AM   #9
Don Landis's Avatar
So, what I read on this site in the labyrinth of posts is that you shouldn't use fiberglass, but instead ABS plastic epoxy resin. Is the West and Mas systems for ABS plastic? Or just another form of fiberglass resin more akin to surfboard repair?
donlandis
Old 09-23-2009, 05:57 AM   #10
Silver Mist
LI Pets's Avatar
Where is this thread did u read that?
Call West or Jamestown see what they say or test a part
WBCCI
Old 09-23-2009, 11:49 PM   #11
Don Landis's Avatar
I like that idea of calling Jamestown. Thanks for the suggestion.
donlandis
mcpd
Old 09-24-2009, 12:15 AM   #12
Alumanutz's Avatar
Profile:  1966 22' Safari
Chico , California
Don, I have repaired lots of ABS in my 1966 Safari. I used fiberglass mat, fiberglass and aluminum screen along with plain ode ABS glue. Check out my blog. I have posted pictures. Blog address is in my sig line.
NUTZ
View my Airstream Blog at www.alumanutz.blogspot.com
Grown men, dressed as clowns, concern me.
Alumanutz is offline   Reply With Quote
Moldings, Exterior Trim Question sailorii Clearcoat, Exterior Paint & Trim 1 08-09-2009 03:15 PM
Bathroom ABS repair-Reality check SilverHoot Upholstery, Blinds, Walls & Interior Finishes 1 07-21-2009 11:02 PM
Flexible moldings Maryw164 General Interior Topics 0 04-26-2009 04:49 PM
Valve repair kits available? Dan S Waste Systems, Tanks & Totes 2 05-14-2007 08:50 PM
Floor repair:epoxy vs resin TomW Repairing/Replacing Floor &/or Frame 11 12-24-2003 12:32 PM
