Old 02-17-2016, 10:16 AM   #1
1973 31' Sovereign
Fort Saskatchewan , Alberta
Above floor Black tank
In my 1973 International I have a above the floor black tank my toilet is attached directly to the top of the tank. Is there a way to remove the toilet from the tank and replace it as it leaks FRESH water all over when I am hooked up or have the pump on
1977 is offline   Reply With Quote
Old 02-17-2016, 10:43 AM   #2
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
You're toilet isn't too difficult to remove,
only two bolts attache it to the flange. My flange screws in to the tank but some might be glued. You don't have to remove the flange to change the toilet.
One bolt is accessed through a round plug that's visible once you lift the seat up. The other is either at the back or under the foot pedal.
You may be able to repair or replace the flush valve or you can get a replacement.
Make sure you get a new toilet the correct height!
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
Old 02-18-2016, 09:29 AM   #3
1973 31' Sovereign
Thank you for the advice I will look for the bolts when is warms up here
Installing gray & black tanks above floor DivineBob Interior Restoration Forum 7 12-02-2015 08:00 PM
Problems with black tank clogging above tank? BoldAdventure Waste Systems, Tanks & Totes 55 01-23-2015 01:32 AM
What to do - Above floor Tank or Below floor tank ??? fatwgn Sinks, Showers & Toilets 8 09-06-2009 02:50 PM
