Old 04-29-2009, 12:29 PM   #15
1969 31' Sovereign
1951 21' Flying Cloud
Alex , Oklahoma
This is really very interesting, I did the paint TUBBY. I really like the finish and so does everyone else who see our bathroom. Not sure how the finish will wear as we don't have any kids to dance around in the tub. If I have a new project in refinishing the ABS, I am going to try this first.
1969 Sovereign
1951 Flying Cloud SS#7062
AIR #18751
CJ of Okla is offline   Reply With Quote
Old 04-29-2009, 01:49 PM   #16
Distantdrummer's Avatar
1975 31' Sovereign
Houston , Texas
What will it do on the wall vinyl?
I hope you tried a bit there too.
And the interior end-caps/domes???
Distantdrummer is offline   Reply With Quote
Old 04-29-2009, 04:40 PM   #17
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Hmmm I just took some 1200 grit sandpaper and lightly sanded and restored to the original color with very little effort.
Afterward I did use Turtle Wax to really get a bright shinny finish.
Garry
Old 04-29-2009, 04:49 PM   #18
Journalist's Avatar
1969 25' Tradewind
Irmo , South Carolina
For those this method doesn't work for, Rustoleum Appliance Enamel comes in a color called "Buscuit" that is almost a perfect match for the original off white plastic used in vintage Airstreams.
AIR #8891
Unrestored 1969 25' Tradewind
Overkill Tow Vehicle of the Year Award:
2001 GMC 3500 4x4 Dually 6.6L Duramax
Journalist is offline   Reply With Quote
Old 04-29-2009, 05:19 PM   #19
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
I've seen people say that about the sanding before, too, and in a recent thread, someone reported using 320 grit, and working up to the super-fine. So I tried a piece of 320...and um...well, I don't think I'd actually live long enough to sand it all down. at least, not by hand. (yikes). I suppose, though, that there are all different levels of yellowing going on. maybe some are just that much worse than others.
"appliance enamel"....that sounds rugged. did you use it? how's it hold up?
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 04-29-2009, 06:04 PM   #20
Journalist's Avatar
1969 25' Tradewind
My dad used it in his '72 to repaint the bathroom sink and shower pan about seven years ago. I used it a couple of years later to repaint several miscellaneous interior bits. It's still holding up great in both trailers, even the shower pan. I just bought a couple of more cans of it last week to paint the air conditioner shroud in my '69, so it is still available and easy to find.
AIR #8891
Old 05-03-2009, 04:16 AM   #21
Power to the People !
Maryw164's Avatar
1972 31' Sovereign
SAN DIMAS , California
Send a message via AIM to Maryw164 Send a message via Skype™ to Maryw164
I'm going to try this method from another thread, along with a good wax type sealer/protectant after:
http://www.airforums.com/forums/f38/...tic-48931.html
I'm afraid that the paint on stuff will just wear off or flake.
Maryw164 is offline   Reply With Quote
Old 05-03-2009, 05:27 AM   #22
Mainstream's Avatar
Louisburg , North Carolina
I removed all the bath from a 78 Sovereign (Rear Bath) and sprayed on two coats of "Tile Doc" two part epoxy paint from Sherman Williams. It is like steel and harder than the Orig. Looked like a new from the factory bath outfit when done,but you must clean with a degreaser then with Zylnol then sand with 220 then re-clean with Zylnol to get all the old soap scum out before painting with anything. That soap scum goes deep and will make any paint fish eye if not cleaned properly.
"Shiny Aluminum Bodies will always turn a REAL man on"
Don't Let the Grass Grow under your Rig!
2004 GMC2500 HD Duramax~ 1987 Avion 30 P
Mainstream is offline   Reply With Quote
Old 05-05-2009, 03:09 PM   #23
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
Holy crap
This is a repeat from my post http://www.airforums.com/forums/f38/...tic-48931.html but worth posting here also.
I tried the Retr0bright on the kitchen window surround it is ABS plastic like the front endcap and has the same print on it. I did some testing before I painted my endcap and do know the print or design on the endcap can be taken off with MEK or Xylene.
The Retr0bright stuff lightens up the ABS plastic but does not touch the print. Wish I had heard about this sooner.
This could be done with out taking the ABS parts out of the trailer, use a 4' shop light with some UV lights instead of the sun.
Bruce,
Parts needed: Fan for roof vent or whole vent fan assembly, vented catalytic heater.
My blog for the 1975 Tradewind restoration, Has not been updated in a while but I am still working on it.
bmklawt is offline   Reply With Quote
Old 05-05-2009, 03:30 PM   #24
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Thumbs up
Excellent!! mine has the same "print", and I was kind of wondering about that...seems that most years have a solid color. The other thing about mine is that it seems perfectly fine; no yellowing at all...except in a couple of spots. maybe its just not subject to alot of direct sunlight?? anyway, I always thought it was in much too good a shape to mess with it. very different from the bathroom parts. I would have guessed that it was made from an entirely different material.
anyway, I'm definitely going to have to try this. Kudos to those who found it!!!
Air:291
Wbcci: 3752
'73 Safari 23'
Old 05-05-2009, 03:53 PM   #25
1975 31' Sovereign
Houston , Texas
Bruce what exactly is the state of the things there in your pictures?
I know those are ABS parts but please be more specific on the areas that are different colors. Was all coated and only some lightened? or is some in the pics still "cooking", or what exactly is happening there?
Is the beige paint or just ABS aging or is that nicotine or what?
Is the "bleached" result uniform regardless of time left to work, or is it critical to time the stuff carefully? In other words will different times of treatment and thickness of standing solution leave a splotchiness of various shades of "renewed off-white"?
Also I am confused about the print on the endcaps. Was there also a print on the kitchen window close-out ? Was the print from the factory you think or some previous owner's brain child?
Sad how this thread which is and was about the new chemical reaction process somehow devolved into a painting one. There are plenty of threads regards epoxy painting and other paints for ABS.
I want to know much more about this "peroxide" method of cleaning/re-newing.
Like what if anything does it do on the vinyl walls, and the mystery composition interior end domes.
__________________________
____ d'drummer ____
...aahh..rumm..pu..tum..tummm...
Old 05-05-2009, 05:32 PM   #26
1976 25' Caravanner
Campton , New Hampshire
I second that ??????
ticki2 is offline   Reply With Quote
Old 05-05-2009, 07:22 PM   #27
StingrayL82's Avatar
San Angelo , Texas
Images: 37
We have the print on our front endcap as well...definitely from the factory that way. This is definitely one of the best ways to restore faded/stained ABS, but does anyone know if there are long-term effects. Another post detailed how bleach will turn the ABS brittle. I know bleach and peroxide are different chemicals, but I'm just wondering if there have been any noted side effects of this cleaning process.
Frederic
1971 Sovereign International - SOLD
2004 F-350 King Ranch
AIR # 8239
EX-WBCCI # 8371
StingrayL82 is offline   Reply With Quote
Old 05-05-2009, 09:55 PM   #28
1976 31' Sovereign
Lake Havasu City , Arizona
We have only had our plastics brightened for about a month on some parts but it doesn't feel brittle or different in any way so far.
We did brighten the plastic surround for our clock and thermometer as well as the plastic cover for the air conditioner. Both of these pieces have a print or pattern on them that matches our walls and there was no adverse effect at all. They turned out great actually.
We didn't plan on using this process for the interior vinyl walls because it is a different material and I believe there were other methods of cleaning it. We were going to skip using it on our endcaps as well because they have many cracks that need to be repaired so we will end up painting these.
When doing the retrobrite I did notice that the brightening would mottle a bit but after my third application the color was nice and even and pretty darned impressive. My plastic looks new. I am beyond happy with our results. I will post pictures as soon as I am home when the light is good enough to take them.
Lisa
bugz42 is offline   Reply With Quote
Great and not so great Florida Parks dancepancha Full-Timing 21 02-18-2013 09:05 PM
Really great folks/ Great forum. rebel beck Our Community 1 06-12-2006 06:33 PM
How can I fix "yellowed" bath fixtures? Wynne General Interior Topics 8 09-09-2004 08:50 PM
Newbie looking to restore old AS Paul Brown Our Community 1 10-05-2002 06:04 AM
Restore vs. Makeover andreaszabo Our Community 8 07-10-2002 06:57 AM
