Old 09-01-2011, 07:58 AM   #1
palmtreegirl's Avatar
2008 25' Safari FB SE
Medina , Ohio
'92 - What thickness of foam
Hello Experts,
This question is about the thickness of the foam on the Gaucho. I want to order new high density foam for the gaucho and new windowseat I made (all the same thickness) in my 1992 Excella Classic. I'm not sure - I've searched and read much - some use 5" and some use 6" - Does it matter?
Does it make any difference with the transformation to the bed? or when the back is in the 'couch' mode?
I plan on wrapping the foam with batting to make it a softer look but I've read that should not be considered when ordering the thickness of the foam. I am also going to make it one piece rather than 3 seperate-looking cushions across.
Thanks for enlightening me.
Liz, Brian and 3 Yorkies
The Silver Pearl & The Black Pearl
2008 25' Safari FB SE Queen converted to King
2014 Ford Expedition EXP Limited 4x4 V-8
McKesh towing mirrors
Centramatic Balancers
Hensley Swift-Arrow Hitch
palmtreegirl is offline   Reply With Quote
Old 09-01-2011, 03:46 PM   #2
Medina , Ohio
Decision
I decided and have ordered the 5" Lux High Quality foam - a full sheet runs $203.65 (82x76) and will be enough to do my gaucho and new window seat with a tiny bit left over. Brian's cousin owns an upholstry shop and will lend me his foam cutting tool. I might have him cover the couch sometime and now I'll have enough foam to do everything.
Memory foam gaucho? CampUnger Upholstery, Blinds, Walls & Interior Finishes 11 09-11-2013 09:56 PM
Kind of foam used in 1969 for twin beds? mrsfixit Upholstery, Blinds, Walls & Interior Finishes 2 07-15-2011 08:25 PM
Help with ordering foam for cushions. Bambi1963 Upholstery, Blinds, Walls & Interior Finishes 4 05-05-2011 07:00 PM
What thickness aluminium ? miscwires Ribs, Skins & Rivets 4 04-27-2011 01:57 AM
'92 Excella - Why 2 pieces of foam in each cushion? NanLynn Upholstery, Blinds, Walls & Interior Finishes 8 01-28-2011 08:45 AM
