Old 02-21-2010, 08:39 PM   #1
Huntley , Illinois
'92 Excella - Why 2 pieces of foam in each cushion?
I'm just beginning to reupholster the dinette and couch in our 92 Excella. I'm curious about why all of the seat cushions have two zippered compartments with a separate piece of foam in each instead of one solid piece of foam? I'm guessing there's a reason, but I can't figure it out. I'm planning on copying the original cushions, and it's going to be a lot more work, so I'd really like to know why they did this originally. Thanks for your help,
Nancy
NanLynn is offline   Reply With Quote
Old 02-21-2010, 08:41 PM   #2
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
Extra comfort?
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 02-21-2010, 08:55 PM   #3
Nancy
The cushions would not stay in place on the seats if they were one piece.
They lay flat for a mattress and bend at 90 degrees for the seat cushions and seat backs. Hence, 2 pieces.
Been that way for over 50 years.
Old 02-23-2010, 06:04 PM   #4
fotochop's Avatar
1969 23' Safari
New Orleans , Louisiana
Images: 18
Wait, are the "2 pieces" like two SEPARATE pieces, like the seat and seat-back of a sofa? Or do you mean two pieces the SAME SIZE (each half-thickness) inside the cushion cover?
I'm about to order foam and would prefer that the cushions stay in place. If having them one-piece is going to make them wiggle around..I wouldn't like that.
fotochop is offline   Reply With Quote
Old 02-23-2010, 08:21 PM   #5
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Welcome to the Forum.
My ’67 had a similar arrangement, however it had the two pieces glued together. I had heard that prior to the manufacture of multi density foam this was a way to provide a good supportive cushion with a softer top surface for sleeping. My brother in law, a retired antique furniture reupholster/refinisher, said this also helped in keeping the covers from slipping by locking the bottom corners into a firmer base. Never the less, after 35 year the foam was a crumbling mess.
Good luck with your project. We’re just up the road from you.
Send us a PM if you ever have a question or need a hand.
Tom.
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 02-23-2010, 11:20 PM   #6
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
back and seat
I redid the upholstery in our 78 Argosy Minuet. The two gauchos were the same. Each upholstered gaucho was composed of a back foam and a seat foam. They were each zipped inside the cover which was joined by a common seam to connect them. This is an important seam as it keeps the two cushions from sliding apart when you lay them flat for a full sized bed. You won't slip between the two parts and hit the bottom!
It is a pain to sew, but I think it is a good design. Take your time and use the old for your pattern pieces if you can.
Lou
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
Old 02-24-2010, 07:07 AM   #7
fotochop's Avatar
1969 23' Safari
Images: 18
OK, so we're talking about a simple hinged cushion, one side functions as sofa/gaucho backrest and the other as seat cushion... I just wanted to verify that.. but it does make me wonder if anyone is tempted to add velcro to their two separate dinette seat cushions when converting the dinette into bed for nighty-night...
my wife is pretty much insisting I do this so she doesn't slip into the gap at night... I keep telling her 'honey you're thin..but you're not THAT thin' ;-)
Old 02-24-2010, 08:13 AM   #8
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Nancy
My 2000 AS also has two pieces of foam in each cushion with the zippers on a material separate compartment. It does make the cushion overall appearance show the change of shape better than a single flat cushion, like a contoured car bucket seat rather than a flat bench seat. I don't sleep on the dinette so I can't say if it improves laying on or not. I did finally figured out the vinyl straps on the cushions stopped it from sliding forward on sitting.
Old 01-28-2011, 08:45 AM   #9
Huntley , Illinois
It was more complicated than any cushion I've ever seen, but I was able to replicate the covers. Does anyone want the old dinette seat cushion covers for patterns?
cushions, upholstery, excella
1988 Excella 32' GVWR Confusion! Rob&Julie Towing, Tow Vehicles & Hitches 26 03-17-2012 02:06 PM
Should I buy a 1979 Excella 24'? (Boy do I want to!!) PuffinPotter General Motorhome Topics 2 07-17-2011 01:47 PM
Help with ordering foam for cushions. Bambi1963 Upholstery, Blinds, Walls & Interior Finishes 4 05-05-2011 07:00 PM
Excella Info? M Williams 1981 - 1983 Excella 4 01-26-2011 07:13 PM
