Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Upholstery, Blinds, Walls & Interior Finishes
Old 11-13-2010, 10:08 AM   #1
1973 31' Excella 500
Phoenix , Arizona
'71 Excella 500 Walls... how to refinish
We are the proud new owners of 71 Excella 500! We are about to start renovation, what would someone suggest for the refinishing the walls? They appear to be plastic or some thing like that... we thought about painting them? Does anyone have any suggestions
kuhldeville is offline   Reply With Quote
Old 11-13-2010, 10:36 AM   #2
redthies's Avatar
1963 19' Globetrotter
1967 17' Caravel
1974 29' Ambassador
Top of the 395 , British Columbia
I have read a few threads here about painting. I lucked out in that our project had already been painted (hideous color, but sticking to the walls), making it easy to change colors. It seems that the main issue is correct surface prep. Make sure you clean / prime with the right stuff, or your color coat won't stick.
If you search you will find all the products you need.
And I will take a few pics of the cabinet mods etc that folks have been asking about and post them in my thread sometime in the next few hours...
redthies is offline   Reply With Quote
Old 11-13-2010, 12:03 PM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Per other's recommendation, we are planning on painting our vinyl clad walls with oil based primer and oil based paint. The key is really good washing and rinsing, rinsing, rinsing before you paint. People have also had good luck with oil based primer, then latex based paint, but some have also NOT had good luck with this method. Since I only want to do it once, I'm going with oil. I won't be able to do it till spring, so I can't let you know how it comes out till then. I also haven't done it yet, so others who have may chime in for you.
Kay
Old 11-13-2010, 08:59 PM   #4
Phoenix , Arizona
will latex primer and paint work?
Old 11-14-2010, 10:10 AM   #5
funkill's Avatar
Tucson , AZ
Images: 27
You might want to read through this post for some info on painting the vinyl clad/coated aluminum paneled walls...
http://www.airforums.com/forums/f39/...ors-62392.html
Oh, and congrats on your new trailer! Post some pics when you have time!
Laura
funkill is offline   Reply With Quote
'71 Excella 500 71excella500 1971-1972 Excella 500 4 04-25-2012 11:24 PM
'77 Excella 500 RockStar Member Introductions 12 05-19-2008 09:49 AM
Painting 1984 Excella Walls Aluminumb 1984 -1986 Excella 5 10-22-2007 07:51 AM
79 Excella 500 Darol Member Introductions 4 06-06-2007 08:56 AM
78 Excella 500 davidz71 Our Community 2 10-17-2002 01:11 PM
