Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Upholstery, Blinds, Walls & Interior Finishes
Old 10-20-2006, 02:04 PM   #1
jdahlen
Profile:  Bloomingdale , New York
66 globetrotter
Just purchased a 66' Globetrotter, walls desparately need cleaning, any suggestions as what to use/what NOT to use?
jdahlen is offline   Reply With Quote
Old 10-20-2006, 02:21 PM   #2
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Start off using the mildest cleaner that'll do the trick. Work up to more agressive if it doesn't work. Never use bleach or ammonia directly on the aluminum bad chemical reactions (fumes) can occur and you could also etch the aluminum. Also be careful using any abrasives on the plastic/fiberglass sink/toilets, they can scratch. Again, if you try the mildest cleaners first, you'll be better off.
I used Murphy's Oil Soap on my cabinets & walls with great success then just went at the troubled areas with 409 or Dow's Scubbing Bubbles or Soft Scrub. In a '66 you have the vinyl walls, I'm told Simple Green works well on removing the stickiness if you have it.
Be sure to take before & after pictures...they are always fun to look back at! Besides, everybody here likes to follow along with your progress and encourage you when needed.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
InsideOut is online now   Reply With Quote
Old 10-20-2006, 02:25 PM   #3
LI Pets
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
I used the krud kutter to remove the the sticky stuff from the walls got it at Lowes 1 gal $10, put it in a spray bottle.
Spray, let sit 5 minutes scrub, rinse with clean wet sponge---done like new
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper | Airbags
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
Old 10-20-2006, 02:51 PM   #4
Wabbiteer
Wabbiteer's Avatar
Profile:  1973 27' Overlander
1972 29' Ambassador
Twin Mosquitos , Minnesota
Krud Kutter has alot of perfumes in it; wish they'd have skipped those ingredients and it also leaves a strong detergent film behind after cleaning.
Diluted it to 1/4 strength it still works good - but count on having to wash it again with windex to get rid of the cloying odor and soap residue since who knows how it will react with the vinyl after a few seasons. A couple of old bath towels and a basin of water also works well.
Powered by Tinnitus
RE & Alt Energy Hope Chest
RE Forums
64 Globetrotter Stove Vent Cover Trotter Roof Vents, Skylights & Fans 2 12-15-2007 07:03 PM
1964 GlobeTrotter InsideOut 1964 Globetrotter 3 09-30-2005 12:56 AM
67 Globetrotter RichardT For Sale & Wanted 1 04-19-2004 11:05 PM
Took Globetrotter on first real trip Jim Clark On The Road... 4 07-01-2002 10:41 PM
Replacing my 64 Globetrotter Floor BobbyW Repairing/Replacing Floor &/or Frame 4 06-28-2002 12:28 PM
test
