We have an Argosy minuet. The gaucho back has a piece of luan under the fabric on the rear side. It's about 2 inches smaller - all around than the cushion. I think this is because when you pull out the gaucho, the supporting frame underneath has luan in the front (seat bottom section) but not the part that is nearer the wall. The luan in the back bolster provides stiffness in this section. OUrs also has a 3rd section - that tucks in under the back bolster, it has wood on the back as well - visable. fabric is stapled onto this section - it's the narrowest section of padding and is intended to fill in the crack nearest the wall.
__________________ 77 Argosy Minuet, 6 metre | 77 Argosy 24, Rear door AIR # 3181 | WBCCI # 5575 Bullies thrive where leadership fails
