Old 04-21-2014, 09:01 PM   #1
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
$6.00 Vinyl Wall Scrubber
Many of us have experienced the stickiness associated with the vinyl coated interior panels on our vintage Airstreams. A search of the forums shows many different cleaning solutions...some work, some don't. We have found that TSP works better than most other products, but may require a number of applications. So in a quest to find an easier way to clean, I came up with a power brush to use on my battery drill. Yes you can find several types online...but I decided to make my own.
A quick stop at Bed, Bath, and Beyond (but probably most grocery stores would have this) and Lowes and we're in business. Take the Good Grips Soap Dispensing Palm Brush and separate reservoir from the brush. Take a 5/16" x 3" bolt and insert it from bristle end through brush, slide on washer, locking washer, and two nuts. Insert in drill and go after the vinyl wall. Take care not to push so hard that the bolt head bottoms out on the wall. The bristles are pretty stiff and light pressure is all that is needed. Sure beats a sore shoulder and elbow!
Indiana, PA TAC PA-5 WBCCI 4871
ID:	210224   Click image for larger version
ID:	210226   Click image for larger version
Roadrunner is offline   Reply With Quote
Old 04-21-2014, 10:24 PM   #2
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Good thinkin! Im in the middle of scrubbing the vinyl right now.
mayco is offline   Reply With Quote
Old 04-21-2014, 10:57 PM   #3
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
holly springs , Georgia
Neat idea. Please describe the whole procedure, that sticky is a pain to remove!!
Kevin
kevinb is offline   Reply With Quote
Old 04-22-2014, 05:39 AM   #4
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Kevin, what we have done is spray TSP (trisodium phosphate cleaner) directly on the vinyl and then go over one square foot at a time. Wipe off with a damp cloth and repeat. You could use a cleaner of your choice but we have found that TSP works best as it is for surface prep before painting. Good luck!
Indiana, PA
TAC PA-5
WBCCI 4871
Old 04-22-2014, 11:24 PM   #5
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
Thanks, I'll give it a try.
Old 05-18-2014, 09:26 PM   #6
sharwest9782's Avatar
1975 25' Tradewind
McMurray , Pennsylvania
Bob,
This is brilliant! I'm totally going to try this!
Thanks!
Sharon
sharwest9782 is offline   Reply With Quote
Old 10-01-2014, 06:52 AM   #7
F1reh0lder's Avatar
1990 34' Excella
Wellton , Arizona
I acquired a 90 excella 1000 and I've just started sifting though the wealth of knowledge on this forum. Will the tsp with the bush take the vinyl off or just do a good job cleaning it?
Thank you for your insight.
F1reh0lder is offline   Reply With Quote
Old 10-01-2014, 07:12 AM   #8
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Just cleaning...you will need some type of paint stripper to remove vinyl.
Indiana, PA
Old 10-01-2014, 07:25 AM   #9
F1reh0lder's Avatar
1990 34' Excella
Wellton , Arizona
Thank you
Old 10-01-2014, 07:46 AM   #10
kevin242's Avatar
1977 25' Tradewind
Waskesiu Lake , Saskatchewan
The cleaning product "Spray nine" took the stickiness off the wall vinyl very effectively in our 1977 Tradewind.
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
kevin242 is offline   Reply With Quote
Old 10-01-2014, 08:05 AM   #11
1988 25' Excella
Trumbull , Connecticut
Cleaning Vinyl walls
Hello fellow Streamers. To get the stickiness off my 88 Excella I use "Pledge Floor Care Wood Floor Finish With Future Shine". This is what Andy at Inland Airstream recommended and I bought it at Wall-Mart. Wipe it on wipe it off, no scrubbing. The walls come out shinny and no sticky.
Happy camping nm1oqrz
nm1oqrz is offline   Reply With Quote
Old 12-16-2014, 07:50 AM   #12
1975 25' Tradewind
Navarre , Florida
Great suggestion. Much better than scrubbing by hand for hours!
Rsmied is offline   Reply With Quote
Old 12-16-2014, 10:54 AM   #13
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
I have used 409. Works great and the stickiness does not return.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
bwoodtx is offline   Reply With Quote
Old 12-16-2014, 12:50 PM   #14
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
My walls have never been that sticky, but I'm totally making one of those for cleaning other stuff - great idea!
Stephanie
Old 01-11-2015, 12:25 PM   #15
Hi, I am novice Airstream owner of a 1957 "ten-panel" trailer, I haven't figured out yet which one it is. It has the speckled type original vinyl coating on the inside walls. I want to have one side stripped to the shiny metal and need advice on which paint stripper to use. I tried "air craft paint remover" and it's not doing the job. Can anyone please give me an idea what to do? Thanks, Andra
Andrameda is offline   Reply With Quote
Best way to remove Vinyl from interior vinyl clad Eric H General Interior Topics 11 10-21-2013 12:32 PM
Roll Vinyl vs. Vinyl Tile in Bathroom? Roadrunner Repairing/Replacing Floor &/or Frame 6 09-29-2011 08:23 AM
new vinyl over vinyl cabinets? Aage Cabinets, Counter Tops & Furnishings 28 09-29-2009 08:50 AM
vinyl tile vs. one piece vinyl loki Repairing/Replacing Floor &/or Frame 69 02-18-2007 04:38 PM
Diamond Plate Vinyl Wall Covering swebster Upholstery, Blinds, Walls & Interior Finishes 0 05-14-2005 08:56 PM
