Old 07-12-2017, 01:48 PM   #1
maa
Katy , Texas
Yet another generator question...2 AC Units
We are taking possession of a 2017 Flying Cloud 25FB unit in about 10 days and need to get a generator as we'll be doing boondocking every once in a while. We've settled on the Champion brand but my question is...the 25FB has two AC units. What size generator do we need? Will 3100 watts starting 2800 running be enough to run both? We are in Texas so AC is a must. Thanks in advance!!
maa is offline   Reply With Quote
Old 07-12-2017, 02:05 PM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
If you want to run both ACs you'd have to parallel 2 3kw generators or get some giant beast of a generator like the 7kw Honda at 260 lb. With a single 3k generator you'll have to choose one AC unit or the other to run at any given time, but frankly I wouldn't worry about it... just plan your boondocking for those few months when it's not summer here in TX and you'll be OK.
David
Old 07-12-2017, 02:24 PM   #3
Mollysdad's Avatar
Since the largest inverter Champion is the 3500, I'd get that one dual fuel.
It won't be able to run two AC's. So your answer will be to use the thermostat, turn one to "Cool" and the other to "Fan Only". That way the air gets circulated but the load is minimized.
Unless you're camping in remote areas you won't run the generator as much as you think. Campgrounds supply 50 amp any more, and if you're stopping for lunch or at WalMart, it's great to cool off, but not 24/7.
To run 2 ac's, you'd need two Champions paralleled, or two larger Hondas, and then you get into weight/fuel/noise factors.
The 7 KW Honda is too tall to fit under a bed cover on a pickup. Everything is a compromise.
Old 07-12-2017, 02:31 PM   #4
maa
Katy , Texas
Ok thanks! One AC at a time then . Is a regular generator okay to use or do we really need an inverter?
Old 07-12-2017, 02:39 PM   #5
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
You'll want an inverter for the quietness, if only for your, and your neighbors, hearing protection and good will. I have been parked next to folks using construction generators and it is VERY annoying.
Some national forest sites dont allow generators at all, even quiet ones. In those situations, solar is a must.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 07-12-2017, 02:41 PM   #6
DKB_SATX's Avatar
1976 Argosy 28
The regular generators are LOUD. If you're camping on land you own and know that no one will be around to complain about the noise, and you don't care about the noise, they're cheaper for the same capacity. If you think you'll ever use your generator camping with a group, camping in a Forest Service or other public lands where someone maybe camped near you, the construction-site generators are rude. If you camp in a national park the loud generators are prohibited.
David
Old 07-12-2017, 02:45 PM   #7
maa
Katy , Texas
Ok inverter it is. We don't want to be the obnoxious newbies
Old 07-13-2017, 10:12 AM   #8
twbucksr's Avatar
2015 22' FB Sport
2018 27' Flying Cloud
Fredericksburg , Texas
I recommend installing the Micro-Air EasyStart 364 (3-ton) Soft Starter on one of your 2 a/c units. It will allow you run one of your a/c units with a single Honda e2000i inverter generator.
https://www.microair.net/collections...nt=30176048267
They were offering a discount when you used the code AIRSTREAM at check out when I ordered mine a few months ago. Not sure if they still are.
I am having my Honda e2000i converted to propane by GenconneX. You can purchase one already converted directly from them.
http://www.genconnexdirect.net/index.htm
Plenty of threads on both subjects in the Boondocking section of Airstream Forums
twbucksr is offline   Reply With Quote
Old 07-13-2017, 10:46 AM   #9
Mollysdad's Avatar
Don't confuse inverter generators with inverters that supply AC from DC.
An inverter generator is one that doesn't need to run at a constant speed to provide stable power.
I think of them as "construction generators" vs. "camper" generators. The camper generators are enclosed, quiet, and efficient, unfortunately, more expensive. Construction generators are intended to run tools like drills and saws, not TV and A/C. They don't provide pure sine wave power, and need to run at multiples of 60. They have open frames, and are offensive to hear, even at a NASCAR race.
Every manufacturer makes both kinds. It's easy to tell the difference.
Old 07-13-2017, 12:02 PM   #10
2018 30' Classic
Newport , Pennsylvania
the Honda 7000 runs both, has plenty of fuel for all night, and makes very little noise. the champion generators are loud and won't run 2
cheap never equates to good, skip the load reduction toys, all these ideas are toys in my opinion. I have a 7000 Honda in the back of my cap that works great.'
Go Big if you want to run with the big dogs or stay on the porch. it appears odd that folks spend big money on a AS and want to generate electric cheap, camp for free and tow with toys!!!
EarlM is offline   Reply With Quote
Old 07-13-2017, 12:06 PM   #11
NCMEDIC's Avatar
2010 27' FB Classic
LINCOLNTON , North Carolina
What he said!!!
NCMEDIC is offline   Reply With Quote
Old 07-13-2017, 04:04 PM   #12
Tbeck11931's Avatar
1990 34' Limited
2013 23' FB Flying Cloud
Conroe , Texas
I realize you have decided on Champion.
Briggs and Stratton has the P2200 and the P3000 that can be paralleled together. I bought my P3000 on Amazon.
Tbeck11931 is offline   Reply With Quote
Old 07-13-2017, 04:32 PM   #13
Glenn T's Avatar
2011 20' Flying Cloud
Lemont , Illinois
Buy 2 generators that weigh under 60 pounds each and link them together to run 2 air conditioners with Easy-Starts installed. That way you'll get the cooling that you paid up for by choosing double air conditioners.
Also, you'll have the option to use just one generator if you only need one air conditioner. By owning two small units instead of one big one, the other will serve as a backup, and you won't hurt your back lifting one big generator.
I'm running my single AC on a 2000w Honda in ECO mode. It works perfectly, and I can lift and carry the generator easily. I'm sure Champion makes something that compares in wattage and weight to the Honda.
Call Matteo at Micro-Air, https://www.microair.net - he'll be able to tell you exactly what you'll need to make this setup happen.
Glenn T is offline   Reply With Quote
Old 07-13-2017, 04:34 PM   #14
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
Micro Air...
I understand the dilemma...We are researching this now also. I like the Champion Dual Fuel 3100 with electric start but it will run only 1 AC. That may not be bad solution to use 1 AC as most 25's came with only 1 AC until last few years. We have had 3- 25's in Austin over the past 8 years, and never had dual AC; survived pretty well.
I think you can do pretty well in a newer 25 with using just 1 AC- the 1500AC unit with the ducted AC. That is unless your in 110 or higher...then I would suggest plugging in to shore power to use both AC's...or stay home till it cools down.
The MicroAir Easystart is certainly a great choice also and will work with your AC units, but seems to work only with Honda 2000i or Yamaha 2000; would not work with my Champion 2000. Yamaha or Honda run around $1K each; so does the DualFuel Champion, and it also has electric start.
So now that I have the new 28' with dual AC, I am leaning toward the Champion Dual Fuel; I called MicroAir and Mateo told me I would not need the Easystart with this unit, so that saves me some money for sure. I have heard of people running 2 generators with 2 A/C's. Not sure you need both in the 25; Perhaps others disagree... If money is no object, I would look at 2 Honda's or Yamaha 2000's with the propane option and link them and also the Micro Airs in each AC unit. I have recently seen posts detailing how to do this off your low pressure propane port. Good luck!
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Yet another "Onan 2.5 KW generator won't turn over" thread DaddysBus Sprinter and B-van Forum 3 05-02-2016 08:02 AM
Are all A/C units Rooftop units? NJtoNC Furnaces, Heaters, Fireplaces & Air Conditioning 5 01-19-2013 09:23 PM
Vintage Units VS New Units Cstar On The Road... 4 05-07-2004 10:22 PM
Yet another newbie towing question cosmotini Towing, Tow Vehicles & Hitches 6 04-30-2004 03:45 PM
Yet another Southern Shine question Rog0525 Cleaning, Stripping & Polishing 48 04-08-2004 02:20 AM
