07-14-2017, 09:01 AM
#21
2014 30' Flying Cloud
Tampa
Originally Posted by lsbrodsky
...For me, the key point was how easily can I lift it and put it in the truck.
That would be an issue if you plan on loading/unloading it every trip. But if you load it and leave it there, what does it matter?
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
07-14-2017, 09:42 AM
#22
Tampa
Two AC's? I scoff at your two AC's!
Did someone say "go big"? Now that's a generator!
07-14-2017, 01:37 PM
#23
2011 20' Flying Cloud
Lemont
Originally Posted by gypsydad
Not sure the 2000W will start up a 1500AC, without the Easystart? Isn't yours a 13.5AC unit on the 20?
Mine is a 13.5 AC - but it's not the stock unit, it's an Atwood. I was upset when the Penguin stopped working after only 4 years, and refused to replace it with the same brand.
The Atwood is the smaller of the two RV models, and is guaranteed to run on a single Honda 2000i. Installation had its challenges, but it was worth it. The 20FC goes from frying pan to meat locker in short order!
07-14-2017, 04:37 PM
#24
2020 28' Flying Cloud
2017 23' Flying Cloud
Hiawassee
, Georgia
Originally Posted by Shiny16
One day I'll get to "run with the big dogs" when I decide to trade my toy grand Cherokee in for an f350 so I can haul a 7000 watt generator and my 16 foot sport. For now I'll just " sit on the porch " with my toy easy start.
Big Dogs make big piles. Do what works for you.
07-14-2017, 05:06 PM
#25
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
One thing to consider:
Even in Texas, it won't *always* be above 90 degrees out. Once you are out of AC season, there still is a lot of the year left before freeze issues shut things down. For that part of the year something a bit less than a triple redundant 15KW turbo diesel setup might be appropriate. One of the advantages of the 2KW generators with a parallel kit is that you can take along one 40 lb item when you don't need the AC.
07-14-2017, 05:27 PM
#26
Hiawassee
, Georgia
Hi
We just got two Wen 2KW units with a parallel kit for those same reasons. Haven't tried 'me out yet but from all the online reviews (multiple sites) they appear to be good units.
Wife & I ended up boondocking for three days in a NJ state park right after taking delivery of our new AS. Didn't know the park had no hookups
1st week of April; cold & wet. We made the batteries last & kept warm & dry. But I think I killed 'em by running 'em down so far. Sure wish I had a little generator then to keep the batteries topped off!
I'll let you know how the Wens work out.
07-14-2017, 05:43 PM
#27
Tampa
True, but that's offset by fueling two generators, pull starting two generators, and twice the noise of one generator. ( a 2K is not half the noise of a 4 K).
The beauty of choice is if it doesn't work out, the generators sell like hotcakes and you can always switch.
I am continually amazed by these generator discussions.
At least it keeps folks from discussing hitches and tires.
For me, the key point was how easily can I lift it and put it in the truck. By all means, if you are a weight lifter, get a big generator and press on.
My solution was to purchase the Harbor Freight 1000# hydraulic table (the 500# didn't go high enough) and use it to lift the generator into the truck. If not in the truck, the generator lives on the table. It's also handy to do oil changes and maintenance at hip level, not on the floor of the garage.
I waited for a 25% off coupon.
07-14-2017, 06:05 PM
#28
2000 25' Safari
Davidson County
, NC Highlands County, FL
Originally Posted by maa
We are taking possession of a 2017 Flying Cloud 25FB unit in about 10 days and need to get a generator as we'll be doing boondocking every once in a while. We've settled on the Champion brand but my question is...the 25FB has two AC units. What size generator do we need? Will 3100 watts starting 2800 running be enough to run both? We are in Texas so AC is a must. Thanks in advance!!
Several people have recommend getting two generators and say to connect them in parallel. That may not work on your trailer if it has a 50 amp 240 v system. 2 generators in parallel still only make 120v.
Trailers with 2 AC units come from the factory with 50 amp 240v system.
Make sure what you need before you purchase.
Alan
07-14-2017, 06:16 PM
#29
Senior Member
2012 27' FB Eddie Bauer
Sparks
, Nevada
Airstreams don't have 240VAC systems...
07-14-2017, 07:10 PM
#30
2000 25' Safari
Davidson County
Yes they do.
Any 50 amp RV is 240v, not 120v. Only if it is 30 amp is it 120v.
If you order a new Airstream from the factory with two air conditioners is does have a 240 v electric system.
Alan
07-14-2017, 08:38 PM
#31
Senior Member
Sparks
, Nevada
Yet another generator question...2 AC Units
Originally Posted by A W Warn
Yes they do.
You don't know what you are talking about ! There are no 240 devices onboard. You have 2 legs each 120vac.
Yes, the outlet you plug in to is wired the same as a 240 outlet but that's where it ends. Proof of this is if you use a 50 to 30 amp adapter everything in the rv will work ( not at the same time) but the entire system is 120vac.
(Retired power company employee )
07-15-2017, 09:24 AM
#32
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
You are missing one very important fact. The connection to the trailer is done with a 50A connector and cabling rated for 50A. It's set up as a 240V circuit so the "two 120V" circuits are 180 out of phase with each other. If you put a voltmeter across the two hot leads, they most certainly *do* read 240.
Since the two circuits are 180 out of phase, with both fully loaded (resistive loads) you have zero current in the neutral. If you have one loaded and the other with no load, you have 50A down the neutral (still fine).
Wire the beast up with "two 120V circuits" in phase and things are a bit more messy. With only one side loaded you have 50A down the neutral just like you did before. With both sides loaded, the current is now in phase, you have 100A down the neutral. That is beyond the rating of the cable or the connector. Worse, since it's in the neutral, there is no fuse or breaker to protect you. You have a very real risk of fire.
A 30A adapter works fine because the neutral *is* rated for 50A. In that case, noting is running over ratings. No smoke, no fire.
If it was a 120V only circuit, we'd call it a 100A hookup ....
Why go on and on about this? It's a very common misconception. If Bubba is wiring up a socket for the RV and gets it wrong ... you can have a fire. The fire could be in his RV. If he works at a campground, it could be in my RV. That's why one needs to be very clear about what should be on those wires.
07-15-2017, 03:46 PM
#33
2000 25' Safari
Davidson County
240v
No need to be upset. We all are trying to help each other, at least that is my goal.
I did not say there was a 240v appliance in an Airstream. I said there was a 240 volt system, the service that feeds the trailer is 240 volt. Two 120v legs create a 240 volt system. There are two buss bars inside the electrical panel energized seperately by each 120v leg.
If a person would connect a 240v appliance to the shore power pedestal it would function correctly because it is a 240v outlet.
The second air conditioner will not work when using the 50 to 30 amp adapter because it is on a separate buss from every other circuit. This is clearly shown on the electrical schematic drawings for the Airstream trailers with two air conditioners, those that are included in the owners manuals.
Alan
07-16-2017, 07:06 AM
#34
Katy
Wow, so much info and I'm as confused as ever, ha!! I think running one AC on a generator will suffice as most of the boondocking will be done in cooler weather. Our trailer is a 30 amp by the way.
07-16-2017, 07:58 AM
#35
Tampa
No.
Trailers with 2 AC units come from the factory with 50 amp 125v. system. Yes, the power post in the Park is wired the same as 240v., however inside the Airstream (and almost every RV) the two hots are never used together. So the result is TWO separate 50 amp 125v. legs each independent of the other.
07-16-2017, 08:32 AM
#36
Senior Member
Sparks
, Nevada
Haven't looked at the schematic but I can tell you for a fact that with a 50 to 30 amp adapter either AC will run. Everyone needs to be aware of this because it could create a potential hazard.
07-16-2017, 08:34 AM
#37
Senior Member
Sparks
, Nevada
Originally Posted by Mollysdad
No.
Exactly! Some of the new large motor homes do take advantage of the 240 potential and are true 240 service.
07-16-2017, 09:04 AM
#38
Central
, Mississippi
Hi...
Since the two circuits are 180 out of phase, with both fully loaded (resistive loads) you have zero current in the neutral...
That is true for 240v systems, the neutral can be cut and everything will still work.
Cutting the neutral on a 50A Airstream results in no power to anything.
On edit, a low amp load on one leg and a high current load on the other with neutrals tied but not hooked to the post causes big problems. The low current device will see over 120v due to the unbalanced load. The neutral does see a load in the Airstream.
07-16-2017, 11:02 AM
#39
2000 25' Safari
Davidson County
If your trailer has only 30 amp 120v electric system it will have problems running both AC units at the same time, whether generator or shore power (assuming they have not been modified). When two AC units start at the same time the current draw would exceed the capacity of the electrical system, which could trip breakers and/or might damage the AC units. The addition soft start system that was recommended in a post above would be a good idea in this case (reducing the current draw at startup).
I have heard of people running a second 20 amp electric cord for a rear air conditioner that plugs in separately from the 30 amp electric cord. I'm curious to find out if this is what your trailer might have.
When you receive the trailer will you follow up with comments about how the system functions?
Alan
07-17-2017, 06:28 AM
#40
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Bingo !
The system in your house that is called "240V" has two 110V legs to ground. Your AS is wired exactly the same way. The proper term for the system is 240V in your house. The proper term for it in your RV is a 240V *system*. You don't always plug everything into 240V in your house, you don't do that in your RV either. That does not change the type of system it is.
If you cut the neutral to your house, things get weird in a hurry. Same thing if you cut the neutral to an RV. In both cases - don't do it, you'll damage things. It also really freaks people out. I've seen it happen enough times to know.
Your house has a 200A 240V service wired into it. That gives you 400A if you use it as 120V. Your RV has a 50A 240V service wired into it. You get 100A if you use it all at 120V.
On your house the power company brings in a bundle of wires. Those attach here and there. They eventually get to your breaker box. You don't plug your house in. Your RV does have a plug. Until the neutral comes loose at the meter, you don't think much about how the power company hooked up your house. Because you have a plug and go around hooking up your RV to who knows what, you *do* need to understand how your RV should be hooked up.
It's a safety issue ... it's important !!!
