Old 06-20-2013, 02:57 PM   #1
1996 28' Excella
Mobile , Mississippi
Why won't my wall sockets work on battery power?
I could have sworn when I did limited boondocking (parking lot etc) in the past they did! (guess I might be mistaken)
I'm on my Mtn top, and the fans, 12 volt pump, lights etc all work fine (should I leave the pump on, or just turn it on when needed BTW?)
But none of my wall sockets have power.
When I plug into my Geny they have power... By not off battery power.
Can't find anything in the manual about this???
(Need to be able to charge the cell and laptop to write reports... Currently using the inverter I keep in the truck)
1996 Excello
Thank you for the help.
Nomadic1 is offline   Reply With Quote
Old 06-20-2013, 03:02 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Your wall outlets WILL NOT WORK from simple battery power when off-grid................UNLESS....................(wait for it).................
YOU HAVE AN INVERTER!
An inverter will take 12VDC battery power and 'invert' or change it into 120VAC house current.
Depending on how you wire said inverter to your existing 120VAC distribution system, you could have the entire coach powered or a few selected outlets. What it will NOT run is your roof A/C, fridge on electric or any resistance type heating appliance (at least not for very long).
That's the simple answer. There are many ways to connect an inverter to your power systems. If you are not familiar with AC and DC circuits, you should have this type of work done by someone who is well qualified to do so.
Old 06-20-2013, 03:04 PM   #3
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
The reason they don't work is because they deliver 120 volt electricity, which comes from shore power or your generator. Your battery provides 12 volts to your low voltage systems. You're power converter takes the 120 volt from shore power and charges your battery and converts down to 12 volt to run the low voltage systems. When you unhook from shore power, your battery takes over.
I would be cautious using your generator as a means to provide power to charge your phone and computer. You can get a USB charger to plug in to a 12 v adapter (like a cigarette lighter) that then charges the phone and computer from your low voltage system.
DryFly is offline   Reply With Quote
Old 06-20-2013, 03:29 PM   #4
1996 28' Excella
So if I understand this correctly I have an inverter between shore power and my plugs, but not between my batteries and my plugs?
(because they work fine on shore power or the geny)
Regarding the potential for the geny to damage my devices with a power surge or drop:
I plugged the 30 amp plug into the geny.
Then used a surge protector/strip to plug the phone/laptop into.
(it has lights which tell you if it's working or not)
IIRC this should protect them from the modulating power of the geny.
(someone please correct me if I'm wrong)
I've got the 200 watt inverter in the truck (cig lighter adaptor as described, no cig lighter plug in airstream) that I power my printer, cell and laptop off of on trips. I'll keep using it till I get this fixed.
Ive also got a 800 watt inverter which connects directly to the battery I keep around for other needs. (powered my mother's freezer during a storm etc)
So I understand, I just didn't know I only had an inverter 1/2 the time (if I'm understanding correctly.
Clarification, and information thusfar appreciated.
Old 06-20-2013, 03:38 PM   #5
lewster's Avatar
NOPE! Not quite that way...............
You have NO INVERTER in your trailer. You get 120VAC from your 30 amp shore power connection, or your 30 amp generator connection. If neither of these are NOT connected...........................(wait for it)..................YOU GET NO 120VAC SHORE POWER.
IF you want 120VAC shore-type power in your trailer when you are NOT CONNECTED to your house outlet or your generator.......then you NEED an inverter to create 120VAC shore power from your batteries.
Otherwise, your trailer only has 12VDC power in it and NO 120VAC if you are not plugged in.
Old 06-20-2013, 04:03 PM   #6
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Your trailer probably came with a CONVERTER. It converts 120 volt to 12 volt when the trailer is plugged in and chargers the battery. If you are running on battery alone you don't have 120 volt unless you have an inverter like the one you have in your truck. It wouldn't be too difficult to wire a cigarette lighter into the circuit on the AS.
What type of generator do you have? Some provide cleaner power than others, the surge protector may or may not protect electronics from "dirty" power that some generators put out.
If you have something like a Honda or Yamaha Inverter generator you will be fine.
Aaron
WBCCI #XXXX AIR #2495
Old 06-20-2013, 04:05 PM   #7
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
MOST of us do not have an inverter. Some have installed one to give them some additional flexibility when roughing it. But the stuff you are most likely to plug into the inverter are likely heavy electric users and most probably upgrade their batteries for that additional power need. Absent the inverter the information above is spot on. Personally I have not felt the need so I don't have one. SO, in summary, if you are not plugged in to a shore power source OR using a generator you DO NOT have any 120v power. Only the 12v supplied by your, hopefully, fully charged batteries.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 06-20-2013, 04:16 PM   #8
1996 28' Excella
I've got a pair of Honda eu200i's (both companion variants so I can plug either into the 30amp plug) which has a circuit protector built in.
airstream does have a converter according to my memory of reading the manual this morning.
I've also got the factor solar on the roof which I'm looking to upgrade.
I'm also using deep cycle batteries (a pair)
Looking to do the best I can...
Sounds like my best bet is to install a 12 volt plug, although it sounds like I'm ok using the Honda and my surge protector when the geny is on.
Old 06-20-2013, 04:42 PM   #9
Ridgerunner3's Avatar
2002 25' Safari
Fountain Inn , South Carolina
Images: 11
My trailer has a 12 volt cigarette lighter type outlet in the bedroom and living area for a 12 volt television to plug in. Check inside the cabinets in the living area to see if you have one of these 12 volt outlets.
Bud
Ridgerunner3 is offline   Reply With Quote
Old 06-20-2013, 04:52 PM   #10
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Those generators are fine for charging electronics. I would double check to make sure you don't have a 12v cigarette outlet somewhere. Look anywhere you might put a television, they were pretty common for that purpose.
Aaron
Old 06-20-2013, 04:57 PM   #11
1996 28' Excella
(removes egg from face) I have one in the living area above the microwave next to the cable TV input.
I don't use the cable, and grew up without TV, and assumed (since it looked a little odd) that it was something for that!
Don't see one in the bedroom, but the one is enough.
I'll need to get another inverter for my truck as its now in the airstream!
Thank you.
-one of the things I love about the Airstream is all the "hidden secrets"
(took me MONTHS to find the rear bumper storage)
Mine was my grandparents who were snowbirds for over 20 years. My grandfather was an electrical engineer for GE for 33 years and there's all kinds of little improvements he did!
Old 06-20-2013, 05:02 PM   #12
Gainesville , Florida
Just in case you do have an inverter installed by a previous owner. It will only work on some of the outlets, and of course must be switched on. Is there a switch that you do not normally use? Jim
Old 08-14-2013, 08:08 AM   #13
janeinthemtns
1985 31' Excella
near Chama , New Mexico
omg. It's a good thing there are patient people in the Airstream world. Otherwise, we would fry our Airstreams and/or blow ourselves up.
janeinthemtns is offline   Reply With Quote
Old 08-14-2013, 11:14 AM   #14
HowieE's Avatar
Princeton , New Jersey
Images: 12
I read this thread and have no idea of what you are attempting to do.
There is no way you ever had power on the 120 volt wall sockets when you were boon-docking unless you were running a generator.
What are you trying to run that requires 120 volts AC. That will determine the size of the inverter you will need to install. Even if installed and hard wired it is unlikely you will be able to power ALL sockets in the trailer unless you have a very large bank of batteries.
2004 Excursion 4x4
