Old 03-15-2016, 09:20 AM   #1
Grapesky's Avatar
2016 16' Sport
Port Saint Lucie , Florida
Cool Where do you get fresh water refills ?
Hope this isn't a dumb question - but as a newbie heading out soon - I was wondering where you get your refill of fresh water to fill your tank while on the road if not staying at parks/resorts but boondocking? I will be carrying an extra container for potable water - but just in case I needed more...
Grapesky is offline   Reply With Quote
Old 03-15-2016, 09:29 AM   #2
Hittenstiehl's Avatar
1961 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Gas stations, rest stops, truck stops, national forest ranger stations, relatives, dump stations for a few.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 03-15-2016, 09:30 AM   #3
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
I have used the water stations found along the road such as watermill. http://www.watermillexpress.com/
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 03-15-2016, 12:21 PM   #4
Ray Eklund's Avatar
2014 25' International
Boulder City , Nevada
Fresh Water Strategy and Options...
That pretty much covers the majority of options.
Now... how to use those options with some strategy.
Have your OWN WATER HOSE. You can also go to Lowes or Home Depot and get a brass shut off valve to connect to the hose for an on/off convenience. Mine comes with a short flexible hose to attach to your longer hose.
Gas Stations: Before filling your gas tank, inquire if they would let you have 25 gallons of water for your trailer. If so, where do you want me to pull the trailer?
If they say... NO. Pull out and go to another station.
Truck stops along major highways. Many have RV and Trailer pumps with dump and fresh water. Make a note in your gasoline log, if you keep one, of stations and mile marker. You never know when you are coming through again.
National Forest and Bureau of Land Management Offices. Go inside and inquire if you could have water for your trailer. I have never been refused. Some have an easy access for Forest Service needs and others are behind a bush.. .so ask where.
Some City Parks have water access. Finding it is another story... the water faucet.
Keep a five gallon water jug, empty. When you have to haul water to the trailer, find a jug with an easy spout to pour into your water tank. Five gallons of water will give you a good work out... if you need 25 gallons.
For dogs. I use one I can set upon a plastic "milk crate" with an spout that I can add water to the dog's water bowl that I place beneath the spout. Five gallons just for the dogs. The best is square to sit well on a flat surface. The lid has a spout that you can reverse to use, that is always with the container. Mine is... blue. Walmart or Lowes might be where I bought two of them. Cannot recall the brand, but when you find it, you will know.
Human Bean
Ray Eklund is offline   Reply With Quote
Old 03-15-2016, 12:27 PM   #5
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Lots of Hwy rest areas also have water taps available near the parking area.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Old 03-15-2016, 12:29 PM   #6
Lily&Me's Avatar
Normal , Illinois
Some of us would have a great deal of difficulty getting a 5 gallon water container high enough into the air to fill our fresh water tank.
I have 2 1/2 gallon, collapsible ones that I ordered online.
Maggie
Lily&Me is online now   Reply With Quote
Old 03-15-2016, 03:00 PM   #7
Ray Eklund's Avatar
Maggie
Maggie, I should have made my post a bit clearer.
Five Gallon Water Jug versus 2 1/2 Gallon Wine Jug... Both are fine options.
Human Bean
Old 03-15-2016, 03:08 PM   #8
Gearheart's Avatar
1973 Argosy 24
Kitchener , Ontario
I have a self priming siphon hose to transfer water into the trailer. Beats pouring it over your shoes. http://www.harborfreight.com/self-pr...ump-47334.html
Gearheart is offline   Reply With Quote
Old 03-16-2016, 10:58 AM   #9
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Silly answer, but...
At J. P. Coleman State Park, Iuka, MS-
The water tastes so clean and clear.
The trailer rides better with a full fresh water tank.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 03-16-2016, 11:03 AM   #10
1967 26' Overlander
Spartanburg , South Carolina
A word to the wise....It is a good idea to use a municipal water supply or a well source that goes thru a purifying process unless you are going to use the water within a few weeks.
Jacob D is offline   Reply With Quote
Old 03-16-2016, 11:14 AM   #11
gainesville , Virginia
When you get your "own" water hose, be sure it's qualified as a food grade water hose.
GEEEER is offline   Reply With Quote
Old 03-16-2016, 12:05 PM   #12
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
A method to get water from a non-threaded spigot to your tank is a must. That might be a water thief and a long hose and tube adapter for the tank end or a funnel/spout/jug that you can lift and pour. Given good clean water at a Gov park, it's a pain to not have a sysem and to have to figure out a way to get water into the tank without spilling half in the process. Now that is a work out. The wine, however, does not seem to be a problem. Unless, of course, the relatives are around. Pat
Old 03-16-2016, 01:43 PM   #13
Ray Eklund's Avatar
Do not fill up your fresh water tank at Sweet Springs, Missouri along I-70 near central Missouri.
It is not sweet. It is mostly SO4 dissolved in the water that might cure Athlete's Foot, but for drinking or worse, your coffee at the local restaurant... a nose turner. They must be pulling the water out of a coal bed full of sulfur and the natural gas is used to heat the town.
Human Bean
Old 03-16-2016, 05:54 PM   #14
2016 26' Flying Cloud
Bastrop , Texas
I've been worried about taking water from anywhere that is not city water i.e. well water, because of all the minerals, iron bacteria etc. in the water and what it would do to the AS plumbing. Not to mention the bad egg gas smell when it is heated up. Living on a ranch I know what it does to the house plumbing, and I use a water softener. What is everyone's experience with well/artesian water?
Tarcoola is offline   Reply With Quote
If you're gonna boondock, when do you fill up your fresh water tank? cantdrv55 Boondocking 23 04-24-2015 09:40 AM
Can't get water to pump from fresh water tank xbr443 Fresh Water Systems 6 01-20-2015 06:34 PM
SODA REFILLS on the Road... Ray Eklund On The Road... 41 01-04-2015 04:29 PM
Propane Refills at Costco perryg114 LP Gas, Piping, Tanks & Regulators 16 05-09-2014 02:03 PM
Best single person funnel for FW refills polarlyse Fresh Water Systems 23 05-27-2013 09:03 PM
